Old August 6, 2009, 11:39 AM
somecanadianguy's Avatar
Default Rotate my LCD monitor?
This may sound like a stupid question... maybe it is...
Will it damage my LCD monitor in any way if I set it up vertically?
It doesn't have a stand that piviots, but there's a spot to attach a wall mount.
I can make a stand easy enough, but I don't want to damage my monitor.
Old August 6, 2009, 11:47 AM
If it falls from being improperly mounted maybe...I can't see it damaging the monitor (correct me if I'm wrong).
Current Rig: C2D E6400 @ 3.0GHz, Vendetta II, BFG 8800 GT, OCZ PC6400 8GB, HX520W, 2x WD 500GB HD, Segate 160GB, WD 200 GB HD, Lancool PC-K62, Windows 7 64 bit, Snow Leopard (on the way)
EVGA 680i SLI Motherboard $80 + Qualitas 73GB 10k SCSI $30
Old August 6, 2009, 02:08 PM
JD JD is offline
Won't do any damage. Lots of people run their monitors vertically.
Old August 6, 2009, 03:58 PM
No, no, no. You can't have the liquid sloshing vertically!
Old August 9, 2009, 11:56 AM
So is it ok to do, or not?
So far most say yes, one says no no no...
I'd really like to have it set up vertically if it definately won't damage it.
I know a lot of monitors can be run that way, but is there any difference besides the pivoting base?
Old August 9, 2009, 12:54 PM
sswilson's Avatar
The only nay sayer was joking..... ;0)
Seeing as how there are no moving mechanical parts to an LCD monitor, I'm sure there's absolutely no reason why you can't mount it sideways (outside of ensuring that the mount is well secured).
Trying to use my LCD TV as a second monitor Lpfan4ever Troubleshooting 7 April 30, 2009 06:19 AM
[WTB] 22'' to 24'' LCD monitor Jacka Buy/Sell & Trade 1 January 27, 2009 05:46 PM
What's the diff between buy a lcd tv and an lcd monitor? Mark Display Units 9 October 27, 2008 07:38 AM
LCD TV as a Monitor? mattlef Display Units 17 September 10, 2008 05:25 PM
LCD Monitor or LCD TV Brando737 Display Units 5 February 13, 2008 02:51 PM
