<~----> LG W2252TQ vs BenQ T241W - Hardware Canucks
Old August 5, 2009, 03:37 PM
Default LG W2252TQ vs BenQ T241W
Hey guys I'm looking for some opinions.
I currently have an LG W2252TQ 22" monitor. Its specs are:
Resolution: 1680 x 1050
Brightness: 300 cd/㎡
Response Time: 2ms (GTG)
Contrast Ratio: 10000:1 DFC (Original 700:1)
So far I enjoy it, however, I'm looking for a monitor with higher resolution.
I found a refurbed 24" BenQ T241W monitor for ~ $200 with the following specs:
1920 x 1200 Native Resolution
Response Time 5 ms
Brightness 250 cd/m2
Contrast Ratio 1000:1
I realize the contrast ratio and response time are significantly lower with the BenQ, but I'm drooling at the resolution it offers.
What do you guys suggest? I like the idea of increasing the resolution, but is it worth $200?
Thanks for all your input.
Case: Coolermaster Cosmos 1000
Mobo: Gigabyte X48-DS4
CPU: Intel Quad q9550
PSU: Corsair 750w
GPU: Diamond HD4870
RAM: 4gb Corsair XMS2 PC2-6400
HDD: 2 x 640gb WD Caviar
Audio: Auzentech Forte 7.1
OD: Pioneer DVR-216
OS: Vista Ultimate SP1
Old August 7, 2009, 10:18 AM
the new monitor looks ok, but the response time is slower, and remember, since the native res for that BenQ monitor is more than the LG, games won't run as fast considering bigger resolutions are more resource-intensive, especially on newer games. I would personally stick with the 22" LG you have right now, it isn't really worth paying 200$ for 2 more inches.
Old August 7, 2009, 11:09 AM
jcmaz's Avatar
+1 to Dimre01. You might not be able to max out every game u play using 19XX resolution using the 4870.
-Plato
BenQ E2200HD: Good Monitor? bovine.baron Display Units 7 March 12, 2009 03:19 PM
BenQ FP241VW Tomvill Display Units 4 September 17, 2008 06:18 AM
