<~----> whats is a good monitor that can double as a TV - Hardware Canucks
Old July 21, 2009, 06:04 PM
Shadowmeph's Avatar
Default whats is a good monitor that can double as a TV
I pretty much live in my Bed room and well that is where I have my PC and My TV I have my TV hooked up VIa s video and the sound from my tv to my receiver via RCA . now what I would like is a monitor / tv up to 26" what are your suggestions. oh I always am using head phones for both TV and PC but I would like to have the monitor have a Head phone plug in so I can turn my reciever off it produces major heat which is pretty good in the winter time buit man does it get hot in my room in the summer time.
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old July 21, 2009, 06:38 PM
gingerbee's Avatar
i think you'll have better luck and it will be cheaper to buy a highend tv
Old July 21, 2009, 06:42 PM
Arinoth's Avatar
+1 agreed with gingerbee, what i use is in my sig and it works great. Only thing i had to do, which i mentioned in another thread is set the resolution setting to Just Scan as monitors have slightly different amount of pixels then TVs do even though they claim the same resolution.
Old July 21, 2009, 06:57 PM
Shadowmeph's Avatar
ok , I have been out of the loop for so long I wouldn't really know what to look for in a TV any suggestions?
Folder :
Old July 21, 2009, 10:07 PM
i just ordered a samsung t220td from ncix for the wife to replace the 32 inch
i had verry bad luck with that daytek 32" 2 of them averaged 40 days n now the psu on it went after a year
dont cheap out get a good brand with a good warranty
i'll be gettin it next week i hope it will be nice + i got the 0 dead picsel warranty
was at a freinds pc shop today and he had installed a 42" plasma i gotta say it looked nice but a bit big as a pc in my view
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old July 22, 2009, 07:59 AM
bojangles's Avatar
Who's Daytek? LOL.
Old July 22, 2009, 08:10 AM
sswilson's Avatar
Depending on how large you want to go, I picked up one of these to use primarily as a TV.......
NCIX.com - Buy Samsung SyncMaster T240HD 24IN Widescreen LCD Monitor 1920X1200 5ms DVI VGA HDMI Component DTV Tuner - LS24TDNSUV/ZC In Canada.
The price was better than any LCD TV I could find, and I'm happy with the results. I know they also have a 26" version, but I'm not sure how well that compares price-wise to getting a standard 26" LCD TV.
One of the main features this has that sold me on it is the ability to set the aspect ratio for viewing an SD source on a widescreen. The cheap 26" LCD TV I had prior to this monitor did not have that ability so all SD sources ended up being stretched across the entire screen. I just double checked, and can verify that it also does have a headphone jack.
The only issue with the monitor is that the tuner does not have an SVideo input so you either have to use the standard cable, or a high-def (either component, HDMI, or DVI) connection.
Old July 22, 2009, 08:20 AM
TopDogZero's Avatar
Good price SSWILSON, if you don't need the tuner this would be a good option . I wanted to get a new LCD TV for the bed room but this looks to be a very good alternative add a TV tuner card in to my second PC for $100 or so and media center and I'm done.
Old July 22, 2009, 08:40 AM
sswilson's Avatar
The monitor I linked to has a full tuner.
Old July 22, 2009, 09:12 AM
TopDogZero's Avatar
My bad, but even better I'm really liking it.
Tags
monitor and tv
whats a good 120mm fan?.......... rob123 Air Cooling 21 July 22, 2009 05:16 AM
Whats a good Water Cooling set up for AmuseMe Water Cooling 13 June 13, 2009 10:01 AM
Whats a good program to split a file onto 2 dvds WolfBane O/S's, Drivers & General Software 3 February 2, 2009 05:47 AM
Whats a good mod for window in CM HAF 932? Lithotech Cases 2 October 15, 2008 02:28 PM
whats a good alla around soundcard? Shadowmeph Audio 16 March 17, 2008 02:53 PM
