Old July 22, 2009, 09:17 AM
Shadowmeph's Avatar
Originally Posted by sswilson View Post
Depending on how large you want to go, I picked up one of these to use primarily as a TV.......
NCIX.com - Buy Samsung SyncMaster T240HD 24IN Widescreen LCD Monitor 1920X1200 5ms DVI VGA HDMI Component DTV Tuner - LS24TDNSUV/ZC In Canada.
The price was better than any LCD TV I could find, and I'm happy with the results. I know they also have a 26" version, but I'm not sure how well that compares price-wise to getting a standard 26" LCD TV.
One of the main features this has that sold me on it is the ability to set the aspect ratio for viewing an SD source on a widescreen. The cheap 26" LCD TV I had prior to this monitor did not have that ability so all SD sources ended up being stretched across the entire screen. I just double checked, and can verify that it also does have a headphone jack.
The only issue with the monitor is that the tuner does not have an SVideo input so you either have to use the standard cable, or a high-def (either component, HDMI, or DVI) connection.
strange .. I replied to this and it didn't show up ( which happens sometimes on this site for some reason)
that is actually a good price, the only thing I would like though is a head phone plug in which I don't thing this has :(
Old July 22, 2009, 10:23 AM
sswilson's Avatar
Old July 22, 2009, 10:42 AM
Shadowmeph's Avatar
ooops I didn't see that I was not quite awake yet thanks for showing me what I missed hehe
Old July 22, 2009, 11:39 AM
Originally Posted by bojangles View Post
Who's Daytek? LOL.
daytek 32 was made by samsung lol
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Tags
monitor and tv
whats a good 120mm fan?.......... rob123 Air Cooling 21 July 22, 2009 05:16 AM
Whats a good Water Cooling set up for AmuseMe Water Cooling 13 June 13, 2009 10:01 AM
Whats a good program to split a file onto 2 dvds WolfBane O/S's, Drivers & General Software 3 February 2, 2009 06:47 AM
Whats a good mod for window in CM HAF 932? Lithotech Cases 2 October 15, 2008 02:28 PM
whats a good alla around soundcard? Shadowmeph Audio 16 March 17, 2008 02:53 PM
