Old July 15, 2009, 01:30 PM
somecanadianguy's Avatar
Default Help me pick a LCD monitor...
Can I get some recommendations for a decent LCD monitor 22" or larger for around $350?
Old July 15, 2009, 03:37 PM
details?
Old July 15, 2009, 07:58 PM
Nodscene's Avatar
Depends on what you are looking for you can get a good Samsung 24" for that price, if you don't mind a TM panel of course. I've been extremely happy with both my Samsungs (a 226BW and a 24" 2493HM) and have no problem recommending them. If you want a higher end panel check out Dell. If you don't need it right away then wait a while as Dell frequently has sales on them. I believe they still carry either IPS or MVA in 22"s.
Create something idiot proof and they will make a better idiot.
_____________________________________
Intel Q6600 - Gigabyte EP35-DS4 - OCZ Reaper 4gig PC2-6400 - XFX 8800GT 512Mb Alpha Dog - AuzenTech X-Fi Prelude - Alesis M1Active MK2 - Corsair HX-620 - Silverstone Temjin TJ05B-X - Scythe Katana 2 - WD Raptor 150Gb - Seagate 7200.11 750Gb x2 - Samsung SH-S203N
Old July 16, 2009, 09:40 AM
Sorry for the quick post... I was being called to go somewhere and had to hurry.
I'll be using the monitor mostly for graphics work, but also some gaming, browsing, ect...
Colours must be fairly accurate, and decent view angle would be nice too.
I'd really like to find a screen that can be rotated and used in vertical orientation.
Even a 20" inch would be ok if it could do vertical.
Old July 16, 2009, 10:00 AM
MonsterSound's Avatar
Default ASUS VW266H 25.5IN $315 (AR)
You might consider the ASUS VW266H 25.5IN Widescreen LCD Monitor 1920X1200 20000:1 2MS VGA DVI HDMI.
At NCIX it's listed at $369 (ar) but you can try to PM at NCIX the
Infonec $315 ( ar) price or Newegg.ca $319 (ar) price.
Plus at NCIX there is currently free shipping when you add a $10 giftcard and you can also get Zero dead pixel Express coverage.
I got one 3 months ago and really like it.
VK266H (same monitor with built-in Webcam is $329 at Infonec and may be a possible PM at NCIX.
Code:
 my Heatware,  RFD &  eBay
MAIN: i5 3570 @ 4.5Ghz wH100 / evga GTX780 SOC / MSI Z77A-G45 / 8gb G.Skill 2133 1T / 30" 2560x1600 / Antec P280 / PCP&C 950w / Intel 520 SSD 240gb / Eclipse / G3-Lazer / z5300 / Win7 Pro64 / APC Xs1300
HTPC : nMedia6000B / AMD X2 4400+ / M2A-VM / Corsair 4GB 800 / LiteOn Blu-Ray / 8800GT / Samsung 46"LCD / 2x2TB / OCZ500 / ATI550 / Wrless Kbrd & Rmte / z-5500 / Win7Pro / APC700
"You must be the change you want to see in the world"
- Mahatma Gandhi
Old July 16, 2009, 11:55 AM
That ASUS looks nice.
Will keep that one in mind for sure.
What about LCDs that rotate to vertical orientation?
Would it damage a fixed horizontal monitor to mod it so it rotates?
[FS] 21" CRT monitor - FREE if you come pick it up! Caldezar Buy/Sell & Trade 21 June 27, 2009 12:48 AM
What lcd to pick? upcoast604 Display Units 4 March 11, 2009 02:39 PM
What's the diff between buy a lcd tv and an lcd monitor? Mark Display Units 9 October 27, 2008 07:38 AM
LCD TV as a Monitor? mattlef Display Units 17 September 10, 2008 05:25 PM
LCD Monitor or LCD TV Brando737 Display Units 5 February 13, 2008 02:51 PM
