Old July 9, 2009, 12:45 PM
Default Quick Question
So lets say I have a 25" LCD and it is connected to my cable receiver( to watch TV ), can I also connect my computer. And change video( 1, 2, 3, 4, etc ) depending on which one I want to use.
I think you can( I saw my friend do it ), but I don't know exactly how to do it. Any help?
Old July 9, 2009, 01:31 PM
jcmaz's Avatar
Source Button (at least on my LG monitor)
-Plato
Old July 9, 2009, 03:58 PM
Arinoth's Avatar
What jcmaz said for changing the video feed you want, you'll likely hook it up either through the VGA connection on the LCD TV if it has it, otherwise you'll need to connect it from the DVI output of the computer with a cable convert to go into HDMI into the TV.
Here I am: here I remain
Quick question jspot69 HTPC Systems & Software 4 February 6, 2009 06:39 AM
Quick Question /b/ derrXIII Video Cards 2 August 12, 2008 02:55 PM
quick question... omgwtf O/S's, Drivers & General Software 14 July 22, 2008 05:31 PM
Quick question Nodscene Power Supplies 2 July 7, 2008 11:27 AM
Quick Question. Khronos Display Units 2 January 7, 2008 02:16 PM
