Originally Posted by jcmaz why would you choose Sharp instead of the other brands? Also, the salesman at Bestbuy told me that LCD Tvs only last for ~4 years b/c of the backlight and tried to convince to buy the crappy Insignia tvs w/ 4 year warranty for ~$500. is wat the salesman said true? |
Yes and no, certain parts are designed to have an average life expectancy of just outside the warranty. One of which is the backlight, however typically nothing bad happens if you maintain and look after your TV (ergo don't leave it on for hours when its not being used, have it hooked up to a stage 1 (or higher) surge protector/power filter). Where Best Buy and all those other stores make most of their money (i say most because TVs still have some mark up on them) is from the extended warranties through their stores and the accessories (used to work for Best Buy). However, if you buy one of those extended warranties, if you have to actually bring in your unit (had fun with this with GPUs that kept dying near the extended warranties with over the counter exchanges) you're getting your money's worth in the repairs.
Hopefully this was enlightening
