Old June 11, 2009, 09:23 PM
crispex's Avatar
Default Color Calibration
I'm just wondering if anyone knows of a good calibration program for a monitor.
My LG W3000H is very heavy on the reds, and I've just noticed some...uh...tearing? Where there are residual colors off to one side of a block of, say, red. This screen happily displays normal colors, but if any primaries appear on the screen, anywhere at all, they are displayed extremely brilliantly. Extremely. (I just played Mirror's Edge like this. It was so amazingly easy to find my way around. )
Really, I should have been checking around for a calibration solution sooner.
If someone could post a few links to good calibrators or whatnot, I think it would make a good sticky for this section, or perhaps the troubleshooting section.
Old June 11, 2009, 09:26 PM
Any good calibrator is going to cost you big bucks.
Old June 11, 2009, 10:10 PM
Thund3rball's Avatar
Spyder Pro is decent and will probably run you $200-$300. It tends to lean a little to the Reds but I don't mind it. Each one leans to one colour more than others it seems. I think for most non-pro graphics users the Spyder is probably the best value.
Datacolor - Global Leader in Color Management Solutions
You can just use an online calibrator if you don't want to spend the money. Less precise but still better than guessing.
LCD monitor test images
"this is not troll. this is real deal!" - hohohee
Desktop:
See the drop down!
Laptop: Dell XPS M1530 \\ T7500 2.2GHz \\ 3GB 667 \\ 6 Cell \\ 8600M GT \\ 200GB 7.2K \\ WSXGA+ \\ Bluetooth/Wireless \\ MS Blue Track Mini \\ Vista Ult. (RED)
HEATWARE
Old June 12, 2009, 08:05 AM
Gellidius's Avatar
I've been using this free program with which calibration is all done using your eyes as measuring instruments; needless to say that results will vary with individuals.
The results i get are quite good.
Hex2Bit - Software by Mike Walters
Jacques
Ego cogito, ergo deus non est.
Old June 12, 2009, 08:38 AM
mklym's Avatar
Any of the 'Spyder3' units are the ones to choose from. They updated the hardware since the Spyder2 series. The Spyder3 series were the highest rated, in the reviews that I read, when I was looking to upgrade my original Spyder.
Current Rigs
Panasonic Toughbooks
CF-18, CF-19, CF-29, CF-31, CF-52GUN
ThinkPads
X301, A31p
There is always something waiting at the end of the road, if you're not willing to see what it is, you probably shouldn't be out there in the first place.
Life's Journey is not to arrive safely at the grave in a well preserved body, but rather to skid in sideways totally worn-out shouting 'Woo Hoo! What a ride!
Old June 12, 2009, 11:57 AM
artistpavel's Avatar
I'm still stuck with Spyder2Pro, it was designed when CRTs ruled the Earth, looking to upgrade to Spyder3 for better Windows 7 compatibility.
х58forLife
Old June 12, 2009, 01:53 PM
crispex's Avatar
So these spyder3's can calibrate your monitor? From the responses so far, it seems that a Spyder would be my only option, as this particular monitor has literally no settings options other than brightness.
(Gellidus, thanks for the link to that. Would probably be all I need, had I any settings options on the monitor itself. Definitely fits criteria for something worthy of becoming a sticky, methinks.)
So, is it worth the $250(ish) USD they're asking for the Spyder3? Seems to be created almost expressly for pictures, too. . .
Old June 12, 2009, 02:08 PM
Gellidius's Avatar
Reminds me that a few weeks ago i wanted to make a small setting change on my lcd, but everytime i pushed a button, it said "osd locked". I was at a loss, now knowing what to do as i had used those some time before and it did work ok.
Someone said "maybe your connection then was analog and now it's digital."
He was right.
could it be the reason you can't make adjustments on your monitor ?
Edit: forgot to say that the program i gave the link for (MCW) has it's own adjustments and there is no need to use adjustments on the monitor itself.
Jacques
Old June 12, 2009, 03:32 PM
FYI... The Spyder will tell you outright that on some low-end LCD screens, it is better to leave them at factory settings. I can vouch for this as I tried to calibrate my buddies low-cost LG TN 20" LCD and it just went whack. o.0
You will have to make some manual adjustments as the wizard on the Spyder goes through the process, the more controls you have, the better. No controls imo, means go with a free solution.
Desktop:
See the drop down!
HEATWARE
Old June 12, 2009, 03:41 PM
crispex's Avatar
Well, I won't personally have to worry about the low-end thing, not by a long shot. Thanks for the warning about that, though.
So, if I have no manual controls, I'm pretty much screwed and doomed to fiddle with freebie programs until I figure something out? Ack. I've been messing with the "MCW" thing for a while now, and if I were to follow it's instructions entirely, well, nothing happens. Fiddling with it while disregarding the instructions only gets me either a bright screen, or darkened colors with bright whites, or some variation of "you-messed-up-the-color-balance-you-moron" type of display. And through it all, the reds remain a brilliant, blinding shade of hellfire.
I need to find one that does all of the calibrating itself, without asking you to change the contrast or anything. The only option available to me, again, is brightness.
I'll keep searching around. Haven't found anything that would work better than the one Gellid posted, though.
Gigabyte Motherboards & Load-Line Calibration... somecanadianguy Overclocking, Tweaking and Benchmarking 27 May 20, 2009 05:36 PM
Samsung 305T (plus) and fine color works SA-SFT fun Display Units 13 April 25, 2009 03:44 AM
Adding color to my computer? BrianHanna New Builds 8 January 5, 2009 08:12 AM
Does anyone know anything about the tagan aplus el diablo case like color etc triumph Cases 4 July 25, 2008 04:37 PM
Green Border/Color Changes Drader Video Cards 0 October 1, 2007 08:43 PM
