Old June 9, 2009, 06:21 AM
Default need some help: "upgrade" for free? or not?
Ok, so I bought a monitor from best buy about 3 weeks ago for a great deal. Its a samsung 2693HM and I got it for $375!. Its a nice monitor, and I love the adjustable height stand.
SyncMaster? 2693HM 25.5? 2693HM - LCD - monitors | SAMSUNG
However, since I bought it the power button is incredibly finiky. It works sometimes, and other times, wont work at all. So I called samsung up the other day to get a replacement (its still under warranty for 3 full years). They said sure, and the monitor would be shipped out in a week. I got an email yesterday saying that they are out of stock of my current monitor but they will offer me an "upgrade" This is the model they offered.
26" HDTV widescreen monitor T260HD - LCD - monitors | SAMSUNG
I dont particularly care about the tv tuner, but it is kinda cool. But is this a better monitor? should I do the exchange or just get my monitor repaired?
Old June 9, 2009, 06:38 AM
jcmaz's Avatar
You should get it b/c it wworth more $$$
-Plato
Old June 9, 2009, 07:55 AM
magictorch's Avatar
I'd be inclined to go with it as long as your comfortable using HDMI cables on your GPU's.
Hopefully it has an older adapter in case you run into issues installing operating systems or issues with display drivers.
Old June 9, 2009, 08:08 AM
sswilson's Avatar
How important is a height adjustment to you?
Without doing a lot of research on image quality, that's the most obvious difference between the two, and would more than likely be the deal breaker for me.
Old June 9, 2009, 08:22 AM
Hopefully it has an older VGA in case you run into issues installing operating systems or issues with display drivers.
Why would I need to use HDMI? it has a dvi input
I'm confused as to "installing" display drivers. Those drivers would be for your graphics cards wouldn't they?
Old June 9, 2009, 08:33 AM
Chos3n's Avatar
Well has long it has DVI inputs, that would be fine. Would you rather wait a long time to get it repaired, or have a screen right away, it's up to you.
So far, the new screen is superior in almost every ways. Only thing, it looks like the brightness isn't as strong as your old one. But for the rest, 5ms response rate on both, 1000:1 white ratio (ignore dynamic ratio). Also, you got more ports, so you can hook up a PS3 or Xbox and play on your monitor at 1080p res.
System | Ragnarok
Case Antec 900
PSU Corsair TX750W
CPU Intel Core i7 2700K 3.5GHZ
Motherboard ASUS P8Z68-V
Memory Corsair Vengeance Blue 8GB 2X4GB DDR3-1600 CL9-9-9-24
Video Card EVGA GeForce GTX 780
Sound Card ASUS Xonar DX
Old June 9, 2009, 08:42 AM
martin_metal_88's Avatar
T 260 have a better image quality then the first one go with it for sure my friend!!!! or ill take it:)
Ask for more
Old June 9, 2009, 08:55 AM
Chos3n's Avatar
Yeah, worst come to worst, just sell the monitor sealed.
System | Ragnarok
Case Antec 900
PSU Corsair TX750W
[FS] Bitspower "bling goodness" D5/655 Mod Kit - BNIB mhw100 Buy/Sell & Trade 6 June 1, 2009 10:18 PM
[WTB] 1/2" "T" fitting for watercooling Toronto122 Buy/Sell & Trade 5 February 26, 2009 10:38 AM
"Girly" 2.5" IDE Enclosures encorp Storage 13 July 14, 2008 09:19 AM
