Old July 7, 2007, 12:53 AM
Question Widescreen or not?for od comp
Hey guys, my old computer have a nvidia 5200fx vid card and it surely doesnt support widescreen.Max is 1280x1024.
What will happen if I connect it to a widescreen 19inch monitor?
Old July 7, 2007, 09:36 AM
The FX5200 supports widescreen. My parents are running a 17" Sharp widescreen monitor (1280x768) off of theirs.
I wouldn't imagine 1440x900 (19" WS) would be a problem for the FX5200, but I don't know for sure.
Old July 7, 2007, 11:33 AM
the fx5200 should support resolutions up to 2048x1536 including most wide screen resolutions below that as well.
ASUS P6T
Intel i7 920 @ 3.8GHz w/ 1.35v
3 x 2048MB PC3 12800 OCZ Platinum XTC @ 1528MHz (7-7-7-20) w/ 1.6v
2 x Sapphire HD 4870 1GB
SoundBlaster X-Fi Platinum
2 x WD1500ADFD RAID 0
4 x WD5000AAKS RAID 0+1
Tt Armor Aluminum Tower
Enermax Galaxy 1000W DXX
DELL 2405FPW, 1905FPW
Old July 7, 2007, 11:18 PM
Im sorry guys, I really thought it was an old vid card so it didnt supported widescreen.
But when I go to the display property to set up the resolution, the max there is 1280x1024. Why is that??
Is it because the monitor only support that as max and when I get a new 19inch monitor more options will show up...?
Im getting so confused.
Old July 8, 2007, 02:05 AM
It won't display resolutions that the monitor doesn't support ...
Old July 8, 2007, 03:46 AM
You got it
Old July 8, 2007, 10:05 AM
Fallen Folder
there is a checkbox option under advanced properties, monitor to display all adapter supported modes including the ones not supported by your current monitor.
New comp for a friend. belgolas CPU's and Motherboards 7 March 12, 2008 08:04 PM
Widescreen Question? Canadianguy Gaming 12 January 10, 2008 11:33 PM
7800gs keeps restarting my comp Crackdaddy31 Troubleshooting 4 November 26, 2007 07:07 PM
Widescreen and avi files? bobaban Display Units 0 November 23, 2007 04:06 PM
My Comp... acolite Case Mods, Worklog & Gallery 3 November 10, 2007 09:31 PM
