Old April 18, 2009, 02:38 PM
Default Can't get refresh rate higher then 60HZ
Hi Guys,
I just bought a new monitor : Acer H233H 23" HD Monitor, I love it!
Problem is I can't get the refresh rate higher then 60HZ on Windows 7 - 1920X1080, According to official website, the box and ATI Catalyst, it supports up to 75HZ on native resolution.. I can't seem to get it higher..
I know all refresh rates convert to 60HZ, thats what people have been telling me.. But I need it to run 75HZ, 60HZ causes tearing in games, yes its fixed when u enable Vsync, but I want to leave vsync disabled..
So my question is how do I force refresh rates in Win7 or with ATI Catalyst? I've tried looking for appz theres none for Vista, only XP..
Appreciate your time and help :]
Old April 18, 2009, 03:08 PM
"Quote This..."
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\DirectDraw]
"ForceRefreshRate"= dword:00000055
Note dword value of 55 = 85 hz
Change dword value to 4b for 75 hz
Change dword value to 3c for 60 hz
Change dword value to 64 for 100 hz
Old April 18, 2009, 03:14 PM
"Quote This..."
If that doesn't wok download ati tray tools.
ATI Tray Tools 1.3.6.1042 download from Guru3D.com
Old June 11, 2009, 09:15 PM
crispex's Avatar
....Can you do that with any monitor? I'm suddenly curious if I could push this monitor farther...
Mind you, I'm asking without having done any research at all, so if it's a retarded question, forgive me.
Old June 11, 2009, 09:25 PM
Originally Posted by Yamcha View Post
Hi Guys,
Monitors are locked regardless.
Even if you could bump it up the panel itself can only do so much. If the panel is a 60hz panel nothing you do will change that.
If you want more than 60hz then you'll need to buy a CRT.
LCD monitors don't use refresh rates they use response time.
Old June 11, 2009, 09:29 PM
Eagle Eye's Avatar
Have you installed the drivers for the monitor yet? I believe Windows regardless of ver. defaults 60Hz for all LCD displays to be safe.
EE
Old June 11, 2009, 10:12 PM
Thund3rball's Avatar
Some higher end LCDs will do more than 60Hz. Such as my Dell 2209WA, it will run native at 75Hz. But as said earlier, you can jig the registry all you want, the panel will only put out what it is meant to.
"this is not troll. this is real deal!" - hohohee
Desktop:
See the drop down!
Laptop: Dell XPS M1530 \\ T7500 2.2GHz \\ 3GB 667 \\ 6 Cell \\ 8600M GT \\ 200GB 7.2K \\ WSXGA+ \\ Bluetooth/Wireless \\ MS Blue Track Mini \\ Vista Ult. (RED)
HEATWARE
refresh rate question tcos HTPC Systems & Software 11 July 2, 2009 11:50 PM
Building a new comp (for gaming). Rate it, change it, opinionate it! chouchou New Builds 22 October 23, 2008 06:37 PM
800$ budget gaming pc... rate/review it!! ellyo414 New Builds 28 August 17, 2008 09:51 AM
Rate my computer build? :) Skead New Builds 15 August 5, 2008 02:20 PM
Hey HWC, rate this build! Khronos Off Topic 9 December 17, 2007 02:12 PM
