Old March 26, 2009, 12:15 PM
marcons's Avatar
Default Projector Noob, need a little help
I recently acquired a a projector from an auction, state of lamp was unknown so i got it really dirt cheap (30 bucks), i got it home and plugged it in and it started up and showed a screen, all blue with the canon logo and started counting down. it got to about 5 secs and goes black. and the replace bulb light comes on.
now this is where the noob question comes in, if the projectors bulb was out would i even get that startup screen and think something else is wrong besides the bulb and save myself some money on a new bulb? or do all projectors show this startup screen even with a bulb that needs replacing.
the model is a Canon LV-5210u , i got the manual online but never saw anything pertaining to my particular problem.
Heatware
Ebay
Old March 26, 2009, 03:23 PM
I don't know if this is manufacturer propaganda, but they always say the bulbs can explode if used significantly past their rated hours.
I'm betting it's false.
That said, if you're quick enough to try to reset the lamp hours you may be able to squeeze out a bit more.
And all the projectors I've had in the past have had a "warmup time" showing a solid color and usually the manufacturer's logo.
Here comes the noob (I bet you're used to it now) Lpfan4ever Water Cooling 10 March 9, 2009 10:48 PM
[WTB] I am a noob and i need some help :D eltiti55555 Buy/Sell & Trade 16 March 9, 2009 01:02 PM
Noob here, trying to get my first WC setup together. jaszypoo Water Cooling 13 December 11, 2008 07:25 PM
RAM... A Noob Question Hail Ceasar RAM 11 December 1, 2008 07:51 PM
