ooh, you got the 1080p ones. why didn't you get the 1920x1200 24" that were going for the same price?
or were they sold out
I could be completely wrong here, but I remember reading somewhere that you could set up xfired ati cards in such a way that, each card could display the image for each monitor. Thus having 3 cards, you could display on 3 monitors.
I think that might be a better option - if its possible - than buying that matrox thing. holy smokse 350+ for that?? isn't it like a multi-tap, but for computer monitors?
You could get a 4850 x2 @ $360 + 4850 @ $170. for the same price as a matrox @ $350, plus whatever card your using. It would also be much more powerful too. Also it might scale better than a reg tri xfire, cuz each card would be supporting its respective monitor.
Of course, if my memory is wrong and I actually dreamed up the possibility of the ati cards doing that, then my solution is moooot.
Edit: I just read the part about you not being able to find games that support the tri monitor. I've seen videos of HL2 being displayed on tri monitor. I also know for sure that fallout 3 supports it right out of the box. You just use the cheat or the setting (can't remember) and set your field of vision to like 170 max i think. I know it would work in your situation because I was able to do it with my one, single monitor. (ever try sing 170 degree vision with a regular aspect ratio? its like putting one of those fisheye lenses on a DSLR, same effect if your using a small screen LOL)
also, now that were on the topic. I think I'll wait till this kind of screen is available,
Next-Gen Displays: Extensible OLED Display Is the Stuff Dreams Are Made Of
before I try the super wide screen. I want this monitor BAD! so I can wrap it around my FACE!
