<~----> Dell SP2008WFP - Hardware Canucks
Old January 17, 2009, 08:19 AM
Default Dell SP2008WFP
Hello,
I have the Dell SP2008WFP and i am looking to mount it on the wall but i am not sure if its possible. I have looked on the internet everywhere and can't find anything that says it can be. I have looked on the back of the unit and don't see anywhere where the wall mount could be attached. Was just wondering if anybody has this monitor and has mounted it on the wall. Thanks in advanced.
Cheers,
Scott
Main -> Running Windows 7 Pro
CoolerMaster Cosmos S | Asus P5Q-E | Intel Q6600 | VisionTek 4870 | Mushkin Redline (4GB)
Secondary -> Running Mac OS X Snow Leopard
NZXT Hush | Asus P5K | Intel E6750 | Nvidia 8800GT | Mushkin HP2 (2GB)
Old January 17, 2009, 08:57 AM
Eagle Eye's Avatar
Dell : Dell Dell SP2008WFP 20 inch Widescreen Flat Panel Display with Webcam : Displays :
According to specifications you can mount this monitor.
MiscellaneousCables Included
1 x VGA cable ¦ 1 x DVI cable ¦ 1 x USB cable
Flat Panel Mount Interface
100 x 100 mm
Features
Security lock slot (cable lock sold separately), wall mountable
Compliant Standards
TCO '99
EE
Old January 21, 2009, 01:04 PM
lcdguy's Avatar
as long as it supports the vesa wall mounting standard it should be doable. Check out HDMI Cable, Home Theater Accessories, HDMI Products, Cables, Adapters, Video/Audio Switch, Networking, USB, Firewire, Printer Toner, and more! for mounts though.
A dell buy mailaw New Builds 2 November 27, 2008 06:04 PM
Dell M1330 darkorb Mobile Computing 14 August 13, 2008 05:25 AM
FS: Dell 2407WFP (Rev. A04) alexroland Buy/Sell & Trade 5 June 2, 2008 04:58 PM
Dell XPS M1530 or something else? Thund3rball Mobile Computing 11 February 17, 2008 12:01 AM
