  #21 (permalink)
Old January 17, 2009, 08:32 AM
If you get a true Microfibre cloth, all you need is water.
I have a product line of "NOTHING ADDED" cleaning products...soaps/cleaners with no additional chemicals, like the UV dye they put in clothes soap(bleach for unbleachables), and a real microfibre cloth can clean kitchen grease off a mirror/LCD without any soap.
My ashtray sits directly under my monitor...as I type there's a trail of smoke gently carressing my monitor...Anyway, in order to properly get all teh smoke of your monitor, you need a specific type of microfibre cloth, due to the texture of the panel.
Also, isopropyl will remove anti-glare coating on LG/Samsung panels. It takes a bit, but after a few cleanings on the same spot, if you rub, you'll rub the coating off. Personal experience here on that one!
Find one like the pink one:
Driver Cleaning Scart O/S's, Drivers & General Software 5 December 24, 2008 12:21 AM
cleaning wc parts phil3_66666 Water Cooling 3 September 27, 2008 04:46 PM
Cleaning RAMchips and other surfaces Cptn Vortex Guides & How-to's 40 August 24, 2008 08:53 AM
Spring Cleaning, enthusiast style Hardware Canucks Reviews & Articles from the Web 0 May 1, 2008 07:46 AM
cleaning my case... omgwtf Off Topic 17 November 25, 2007 03:26 PM
