-   Display Units (http://www.hardwarecanucks.com/forum/display-units/)
-   -   2 computers, one monitor....... (http://www.hardwarecanucks.com/forum/display-units/13386-2-computers-one-monitor.html)
rob123 December 30, 2008 05:41 PM
nearly have a server finished and was wondering about a monitor. dont really want to buy a monitor just to look in once in awhile on the server. i thought about a kvm switch but reviews i have read on nearly every model out there are not encouraging.
so, i have a samsung syncmaster 226bw. we all know it has 2 inputs. dvi and vga.
right now i have my system hooked up to the dvi port. can i hook up the server to the vga port and simply switch between the 2?
i realize i would have to get another keyboard and mouse but with all the boxing day specials out there , that wouldnt be a problem.
thx for any info
rob123
sswilson December 30, 2008 06:03 PM
Yes. I ran the exact same setup for a while with my Samsung 19".
If you want to use the same keyboard/mouse you can pick up a KVM switch, or there's a few decent programs out there that allow fairly seamless switching between two different computers (basically remote control).
BT! December 30, 2008 06:06 PM
unless there is a input select i dont think you'll be able to switch, you should set up your server so you can log into it through remote desktop, just like you would do for a colocated server.
sswilson December 30, 2008 06:09 PM
I've owned 3 different samsung model LCDs, and each one had an easily accessable input switch.
BT! December 30, 2008 06:11 PM
just googled it and seen it has a "source" button, you should be able to use it for both. also, if you want to share the keyboard and mouse theres a program called Synergy that works well through your network. easy to set-up if you follow the directions. :)
rob123 December 30, 2008 06:13 PM
actually there is an input select. i only have samsung monitors and i thought all monitors had them. i can pick between analog or digital.
SS Wilson, i thought about kvm switches. besides widely differing prices there were 2 extremes of opinion on nearly every model i could find. there didnt seem to be much of a consensus on any model, except perhaps the vga only ones and i have no use for that.
besides i can pick up a mouse/keyboard for $25 at a boxing day sale.
cheers and thx
rob123
BT! December 30, 2008 06:17 PM
never owned a samsung, and my old benq and sonicviews never had a way to switch. my new benq does though :D
lowfat December 30, 2008 08:22 PM
My vote goes just to use VNC. I control 3 PC's via VNC on my Mac. A lot easier than changing the inputs all the time.
Cptn Vortex December 30, 2008 09:02 PM
Rob, I have a Desktop and a Server, and I was using a basic USB KVM switch to switch the keyboard and mouse between computers, then I just manually selected the input on the monitor. This way I just didnt use the VGA cables from the KVM, only the USB part.
CanadaRox December 30, 2008 10:08 PM
Another vote for VNC. I've used one to control my server for a while now.
