  #21 (permalink)
Old January 6, 2009, 03:01 PM
geokilla's Avatar
Originally Posted by confusion View Post
I've got the Sony TV and the upconverting of signals from the SVid and Composite cables is phenomenal.
I'm sure this will be the standard with all newer TV's, but so far I think Sony has done it best.
Now, that being said, the best thing to do is get a receiver to do all the 1080p upconverting.
I think my mom would like to get an upconverter. We're currently using the standard Rogers digital cable stuff and the quality isn't as good as it can be. Of course, I still need to calibrate the TV.
Oh, and don't forget to update the firmware. It helps a lot.
  #22 (permalink)
Old April 30, 2009, 01:39 PM
You do realize that SAMSUNG makes the LCD Panels for SONY however sony might switch over to SHARP. Anyways, its almost the same TV so get the Samsung because its probably $100 cheaper.
I've got a link to an article pertaining to this somewhere..
  #23 (permalink)
Old April 30, 2009, 01:40 PM
Here it is...
Sony to buy LCD TV panels from Sharp: source | Technology | Reuters
  #24 (permalink)
Old April 30, 2009, 01:41 PM
You'd be crazy to buy a TV from SONY nowadays when Samsungs are much more nicer.
  #25 (permalink)
Old April 30, 2009, 03:47 PM
gingerbee's Avatar
i have to say samsung jmo. i don't like the pastel color you get from the sharp tv's. and yes i know they can be adjusted
  #26 (permalink)
Old April 30, 2009, 06:48 PM
hightest's Avatar
well i no u allready bought your t.v.but myself i got most of my info frum avs forums 2.then i went shopin.
i bought the 52"sammy 750 about a year ago and i luv it.then replaced comp monitors with sammy32" 550's.and there great 2 piad about $650;00 4 them.then we needed 1 more so i picked up the sonybravia kdl-32vl140 got it on sale 4 about $650;00,this sony model is almost xact same specs as the xbr6 model munis the housing and and 1 or 2 other things cant remember what they r thou
but out of the box the sammys didnt need any fine tunning,4 me.but with the sony i had 2 fool around with it 2 get it the way i liked it.but i allso bought this sony instead of another sammy 550 bcause it had more options 4 the t.v part of it like the biult in t.v giude ect.
and im thinkin of tradin the sony 4 the sammy 550 that was 4 my son.only my opinion but every time we went 2 buy a lcd the sammy"s just looked better 2 me,and the sound seemed better 4 what u can test and c at the store
i made a thread comparison with pixs of the sammy32" 550 and the sony kdl32vl140 but i cant find it. i'll make another thread of the 2 t.v's soon with pixs.
just a side note my mum dad,brothers and sisters family all bought the sharps 8 series and the 9 seriers s.e,and my bro bought the 32" sharp gammers edition 4 his comp.and they agree that the sammys p q is much more vivid.but if your room is very bright eg lots of sunlight frum a big window the sammys and sonys u will c a reflection frum the light.bcause the sharps have a matt finish u never c the glare frum any light.
so if your room is very bright even thou i luv my sammys/sonys,i wood say get the sharp unless u can place the t.v were u wont get the reflection frum the sunlight,bcause i had 2 change livin room around so i wood not get that reflection frum the big livinroom window
well im startin 2 babble on i'll put these things i've found out in my thread that i do up
Man all this computor stuff is 2 addicting.Even thou i dont need 2 i allways wanna upgrade.
  #27 (permalink)
Old April 30, 2009, 06:58 PM
Dazmode's Avatar
Sony and Samsung are two top brands. It is like AMD vs Intel discussion. Having said that I like and use Sony.
Orange Build: Final Video
HTPC Build: Final Video
  #28 (permalink)
Old April 30, 2009, 08:05 PM
Chilly's Avatar
Two Sony Ericssons vs Samsung INNOV8. Which to get? geokilla Off Topic 1 December 9, 2008 02:41 PM
FS: Mac Mini G4 / Samsung 204B LCD / Samsung HD960 Upconverting DVD (Faroudja) Thund3rball Buy/Sell & Trade 13 March 7, 2008 10:21 AM
