Old November 28, 2008, 09:38 AM
"Quote This..."
None of the newer TV's have DVI ports. All hdmi. And a legacy VGA.
SKYMTL's Avatar
HardwareCanuck Review Editor
Originally Posted by Eldonko View Post
Yah usb port is a nice feature.
I agree, it is a great feature even for viewing photos.
Old November 28, 2008, 09:40 AM
BALISTX's Avatar
I'm a total noob when it comes down to HD TV, but I have one question: no DVI port? Or does the HDMI ports take over?
HDMI takes over. If you are connecting a something that does not have HDMI and has DVI you can run a DVI to HDMI cable, that will handle the video but for audio you would need to resort to either running component to the TV or like most run optical cable or SPDIF to a stereo receiver.
Heatware
HWBOT
SKYMTL's Avatar
HDMI 1.3 can do everything DVI can and then some so it has become the standard. In addition, it is next to impossble to find a Blu-Ray or even upscaling DVD player with DVI these days so it is pretty much poinless to have it on a TV.
Old November 28, 2008, 09:48 AM
SKYMTL's Avatar
Correct me if I'm wrong but isn't S/PDIF an audio FORMAT that can be carried on Optical (TOSLINK) cable OR an RCA-style Coax cable?
Old November 28, 2008, 09:51 AM
BALISTX's Avatar
SKYMTL: you are right. My friend that has a 65" TV has his HTPC connected to his TV via DVI to HDMI since he does not have HDMI on the mobo and has a optical cable running from his soundcard to his stereo receiver.
Heatware
HWBOT
Old November 28, 2008, 10:41 AM
Trial Member
Thumbs up Awesome Review
Hi,
Thanks for the great review.
My respect for your site just went up a few notches. Was considering registering but had held off till now.
keep up the good work.
Regards
Old November 28, 2008, 11:08 AM
SKYMTL's Avatar
Originally Posted by speedfreak365 View Post
Hi,
Regards
Thanks for the compliment.
  #19 (permalink)
Old November 28, 2008, 11:12 AM
Eagle Eye's Avatar
Its gets better speedfreak and welcome to the forums!!
Sky that Rabbit would have been dinner had it chewed through any my electrical components, another great review and I look forward to seeing the update say with a little bluray content. Although the images looked damn impressive can it really look any better?
  #20 (permalink)
Old November 28, 2008, 11:16 AM
Eldonko's Avatar
Hardware Canucks Reviewer
That is correct, SPDIF is just the digital audio format and can be transfered via optical or coax.
