Old November 20, 2008, 10:57 PM
Default Dual Display question....
Ok i have a weird question. I am using a 24" and 20" monitor in dual display.... now normally i would just have the 24" then the 20". So to get to the other monitor you just slide the mouse to the right.... but what if i have my 20" mounted above my 24" is there anyway to set it up so i would slide the mouse up to jump monitors?
Thanks in advance for any help.
IM THE DUDE, PLAYING A DUDE, DISGUISED AS ANOTHER DUDE.
Old November 20, 2008, 11:11 PM
Vista or XP should both allow you to specify where your monitors are and I think you can stack them. Just go into your monitor properties.
Old November 20, 2008, 11:24 PM
"Quote This..."
yep, in the dual monitor setup screen where you see the monitor icons labeled 1 and 2, you can simply drag the icons around to match their actual locations.
Old November 20, 2008, 11:32 PM
sweet... not sure why i never though of trying that. thanks =)
