Old November 20, 2008, 10:54 AM
Default Help picking an LCD tv (I got it down to 3 choises)
I would like some help in picking an LCD tv, I got it down to 3 choices but I don't know much about display units so I was wondering if some of you can help me decide between them. Thay are: LG 32LG70 LG LCD Flat Panel - Model 32LG70: TV|Audio|Video > LCD Flat Panel > 32LG70; Samgsung LN32A550P3F LCD TV - televisions SAMSUNG; or the Sharp Aquos LC32D64U Sharp.ca Sharp at Home
They are all around the same price at futureshop. So which one do you think I should get?
Old November 20, 2008, 10:56 AM
lowfat's Avatar
I've been using the LC32D64U for ~ 5-6 months as my display and absolutely love it. I have absolutely no complaints with it.
Old November 20, 2008, 11:04 AM
Did you have to do much tweaking with it, things like that really gets on my nerves?
Old November 20, 2008, 11:23 AM
lowfat's Avatar
None really. VGA only will do 1600x1200. But who still uses VGA these days. The TV came in demo mode (they aren't suppose to) but it was rather easy to fix. Besides that colours were set rather well. Firmware is also really easy to update.
Old November 20, 2008, 11:33 AM
So your using DVI? I am guessing.
Old November 20, 2008, 11:38 AM
lowfat's Avatar
Well I use my TV for xbox, wii, macbook pro, pc, and satellite. But I use a receiver to switch between them all. And am only using HDMI between the receiver and the TV. I have used components, DVI, HDMI on the TV though. All of which looked great.
Old November 24, 2008, 02:46 PM
hightest's Avatar
well ive been using the 52inch 750 samsung model which is an awesome tv for pq for gamming and watching tv wether your close or fare for viewing distance so i would say the samsung 550 because the specs are a little better than the 64u sharp model and its only $50;00 more im actually going 2 get the 32 inch 550 samsung just hopin a sale comes up soon
not sure what u want 2 spend but my brother just got a sharp 32inch gammers model from memoryxpress its on sale now 4 $999;99 and he loves it
Man all this computor stuff is 2 addicting.Even thou i dont need 2 i allways wanna upgrade.
Old November 24, 2008, 03:20 PM
For a good entry level lcd tv I simply cannot stress enough the Sharp Aquos series.. for the price and picture they are unbeatable.
Old November 24, 2008, 03:52 PM
"Quote This..."
Future shop has the LC37D64U (37") on for $899. $100 more than the 32" with a wall mount for an extra $30. I traded the 32" in yesterday (had it for less than 30 days) Loved the 32" So far so good with this model. Having it farther away is really good on my old assed eyes.
Old November 24, 2008, 03:57 PM
hightest's Avatar
my parents went with 2 of the sharp 9se series,my brother went with the 2 sharp 8 series and the 32inch gamers series,and my sister went with 2 of the sharp 8series to and they really like them
biggest thing i dont like about the samsung if your in a room with lots of sunshine u will get glare
