Absolutely not, they should be 100% silent as most these days don't even have a fan.
DISCLAIMER: The views and opinions expressed in the immediately preceding post are those of encorp and do not reflect the views and/or opinions of family, friends, or anyone remotely associated with encorp unless explicitly stated. encorp does not make any warranty, express or implied, or assumes any liability or responsibility for the quality, factuality or use of information in the immediately preceding post.
Basically turn the brightness up full on the monitor using the monitor's controls and then use your video card software to turn down the brightness. It is something in the monitor's electronics that creates the whine when dimmed. Using the vid card's controls doesn't affect the monitor's electronics.
ASUS P5Q-E - E8400 (4GHz) - Corsair TX650W - 2xHIS HD 4850 IceQ Turbo - 2x2GB Mushkin Ascent 8000 - 2xWD 500GB - TRUE 120 - Antec 1200 - ASUS Xonar DX - Big Smile
It is quite common. It's the vfd variable frequency drives. your 120volt ac is fed through the wall at 60hz. It gets converted to DC and then back to ac with the cycles varying with the output. You get a lot of white and you can hear the vfd cycling at some god awful speed. My plasma does this when i am using the htpc and surfing, doesn't for movies.
