Old October 18, 2008, 07:42 PM
Mark's Avatar
Question What's the diff between buy a lcd tv and an lcd monitor?
With the pricing of TV LCD monitors dropping - just seen an good deal on a 46" Aquos at Best buy - vs and LCD Monitor. Inch per inch it seems that the computer monitors are very inflated.
I'm looking into buying a new LCD but I'm looking for something around the 24" at least for my Crysis:).
I've seen the top of the line of NEC 24"WMGX3 online but it's a MVA screen and my basic understanding is that the ones to look for are the S-IPS. Can't seem to find any 24" S-IPS screens at all.:help:
CHEERS
Old October 18, 2008, 07:50 PM
biff's Avatar
I'm not an expert but I'm going to guess resolution, all HDTV's are only designed for 1080p no mater how big. A 24" LCD monitor will do 1920x1200 and when you get to 30" you're into 2560x1600 resolution which is ~ a little over double the pixel count over HD.
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
Old October 18, 2008, 08:10 PM
Mark's Avatar
I see. Is there a site that has a non biased view on the best 24" gaming LCD on the market?
Looking at this
LCD2490WUXI-BK
Big bucks - around $1100 bucks
H-IPS screen
Buy LCD2490WUXI-BK 24IN LCD 1920X1200 LS BK 16MS
CHEERS
Old October 18, 2008, 08:23 PM
pixel count mostly.
Old October 18, 2008, 09:39 PM
"Quote This..."
Looking at this
LCD2490WUXI-BK
H-IPS screen
16ms response time will give you visible lag and ghosting.
Old October 26, 2008, 11:52 PM
Mark's Avatar
Yeah, I suppose but other then a Dell or Apple - what IPS monitors in 24" are there without so much lag?
CHEERS
Old October 27, 2008, 12:21 AM
Cptn Vortex's Avatar
The NEC's are not really geared towards gaming. They are more for professional use.
The Dell's and the benq FP241W are some great 24" non-TN panels. They will do and are around $500+
I use a 1080p 32" Sharp Aquos and absolutely love gaming on it. I'll never go to a 24 even if they say it has a better panel. For my needs, my Aquos is perfect.
The Vortex H20
Corsair Obsidian 500D
Asus X99-E WS
i7-5820K @4.2GHZ
RTX 2070
4x4GB Corsair LPX 2666MHZ
Thermaltake Toughpower 850W GOLD
960GB ADATA SX8200 NVME
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
EK Supreme HF, EK Vector RTX2080 FC, EK Coolstream XT 220 Rad, MCR320 Rad, EK-XTOP SPC-60 Pump, EK Multioption 100ml Res
Old October 27, 2008, 07:03 AM
The viewing distance on LCD TV's is usually far greater than an LCD monitor; you have to be careful because even the best of LCD TV's can look like complete crap if you're 16" inches away; that's not to say ALL do but generally LCD Monitor's are designed for up close use with an emphasis on frame transition >3ms response; and TV's also tend to have less contrast ratio right now as well.
If you watch a lot of media on your computer like movies. or blue ray etc an LCD may be good for you but if you're a gamer you really need an LCD monitor; with the exception of course of the few TV's out there that are great for either purpose but those take research to find.
Old October 27, 2008, 07:37 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
An LCD TV will also have a built-in tuner while a "monitor" will not.
Old October 27, 2008, 07:38 AM
Mark's Avatar
I've opted out of the idea of the NEC.
My viewing distance will be around 24-30" so I don't think an LCD TV will do.
Very hard to find a good gaming NON TN panel these days. I have no idea what to get.
CHEERS
