Old October 13, 2008, 07:20 PM
Infiniti's Avatar
Level up: 89% Level up: 89% Level up: 89%
Level: 14 - 64 points to level up
Default Two 22" vs. One 24" Monitor
Which would be better? Two 22" or one 24" monitor? They are both about the same, but the two 22" will cost me 20$ more.
CPU | Intel E6750 @ 2.66Ghz (Water)
MoBo | Asus P5Q-E
RAM | Corsair XMS2 4GB
GPU | Diamond Radeon HD4870
PSU | Corsair620HX
Case | Cooler Master 690
Damn... My E8400 died.
"LOLOMGWTGdairyqueenLOLOMGBBtheQ!" -An Oxhorn Brand Medley
Old October 13, 2008, 08:23 PM
joeperson's Avatar
Level up: 65% Level up: 65% Level up: 65%
Level: 6 - 38 points to level up
I'd go multi monitor but I'm not personally used to anything bigger then 22. Not really aware of the limitations of a giant monitor compared to the limitations of two smaller ones.
Old October 13, 2008, 08:33 PM
Thund3rball's Avatar
Level up: 51% Level up: 51% Level up: 51%
Level: 14 - 285 points to level up
First of all, which 22s and which 24? If you are looking for quality, likely the 24 will be better depending on the model. But if quality is not so much an issue for you than a multi screen setup is very nice. I use multi at work and it rocks. Also what will you be doing mostly. If you are going to be watching a lot of movies it'd be nicer to have the 24. Your 4870 should power a 24 without much trouble for games so that's not a concern. What's your reason for the possible multi setup?
Desktop
AMD 5000+ BE @ 3.2GHz \\
Tuniq Tower 120 \\ Gigabyte GA-MA770-DS3 \\ Mushkin 2x1GB HP2-6400 \\ Corsair HX520 \\ Evga 8800GT SC w\Zalman VF900 \\ Seagate 3x250 7.2K \\ Dell 2007WFP \\ Razer Deathadder \\ XP
Laptop
Dell XPS M1530 \\ T7500 2.2GHz \\ 3GB 667 \\ 6 Cell \\ 8600M GT \\ 200GB 7.2K \\ WSXGA+ \\ Bluetooth/Wireless \\ Vista Ult. (RED)
Old October 13, 2008, 08:41 PM
Infiniti's Avatar
I'm getting the cheapest monitors at NCIX because I'm on a budget. I'm using them for my new system, which I'll be building in the next two weeks. I photoshop a lot, do some rendering, play a little games, and sometimes watches movies. The only reason I want a multi monitor setup because its roughly the same cost from two 22" to one 24".
MoBo | Asus P5Q-E
PSU | Corsair620HX
Old October 13, 2008, 09:09 PM
Level up: 14% Level up: 14% Level up: 14%
Level: 17 - 687 points to level up
Well in that case, both are going to be TN panels so quality wise, they'll be about the same.
I'd go with dual 22" since that's way more real estate than a single 24", plus gaming on a single 22" (1680x1050) is less taxing than on a 24" (1920x1200).
Xeon Quad X3350 | 3.40GHz (Damn X38 chipset)
ASUS Maximus Formula | BIOS RF0410
2GB Corsair Dominator | 850MHz
4-4-4-12-2T
2GB OCZ Platinum Rev2 | 850MHz 4-4-4-12-2T
HIS ICEQ4 Turbo HD4850 @ 700/1200
X-Fi XtremeMusic
Antec TruePower Quattro 850W
Antec 900
[ HEATWARE ]
Old October 13, 2008, 09:20 PM
llama_egg's Avatar
Level up: 28% Level up: 28% Level up: 28%
Level: 12 - 291 points to level up
I agree, duel them, you'll find that once you get use to it, you'll never want to go back. Also, I find it really does help when using programs such as photoshop, you can literally have every window open and out of the way :D
Seriously people, I am not a mod. Stop messaging me D:
Old October 13, 2008, 09:44 PM
Level up: 8% Level up: 8% Level up: 8%
Level: 14 - 540 points to level up
If your planning on learning 3ds max, a dual monitor is the way to go for sure, having the tutorials page open on one monitor while working on the other is heaven. Also, having materials windows, photoshop,, modifier properties, msn.... blah blah blah open on the other display while working is nice too.
AAAlso, if your running XP you can use nview to settup the two monitors as one desktop and you can game on the pair as one. you'll have a nasty break in the middle, but its surprisingly easy to get used too. FPS games kinda suck because you aim in the middle, but any other gamess are ok.
if you've never had multiple monitors before, do it. after you do it once, you'll never be able to go back ;)
vista 64 on these rigs
Q9450 @ 3.5Ghz | E8400 @ 4.2Ghz
8gb Muskin Redline. | 2gb Kingston Hyperx
________________________________|_________________ ______________
EVGA 780i FTW ----\--||___||--/---- EVGA 780i SLI
Antec TP Quatro 1000W \ :==^==: / Antec TP Quatro 850W.
Nvidia 9800 GX2 X 2 SLI \|--o--|/ Nvidia 8800 GTS X 2 SLI
1X 500GB Western Digital. \_____/ 3X 150GB WD RAPTOR RAID-0
Old October 13, 2008, 11:21 PM
Infiniti's Avatar
Okay, dual it is then. Thanks for everyone's opinions.
MoBo | Asus P5Q-E
PSU | Corsair620HX
Old October 14, 2008, 07:40 AM
DK2's Avatar
DK2 DK2 is offline
Level up: 79% Level up: 79% Level up: 79%
Level: 12 - 88 points to level up
Question is do you want 1920x1200 or not, that’s really the only reason for going
24”. The actual size in inches of the viewing area isn’t that much difference.
With two 22” you get more total viewing area, obviously!
Custom Armor case / Gigabyte X48T / Q9550 3.2GHz / Coolit Elite CPU Cooler / OCZ Platinum 4GB DDR3
EVGA GTX 280 SSC / 2x VelociRaptor HDD RAID0 / 2x HDD 750GB / 2x Samsung DVD Burners
Razer AC-1 Sound card / 6600GT video card / ToughPower 850 Watts / 24 & 20 inch Monitors
My Pet Monster
Old October 14, 2008, 07:51 AM
arekieh's Avatar
Level: 11 - 292 points to level up
I have a 22", and my brother has a 24", the difference is noticeable, but definitely not worth the extra cash. If i was you the decisions would be 1 vs 2 22" if your on a budget, and since you say you photoshop alot, duel monitors would be a big plus. Multitasking ftw
| CPU: E6750 @ 4.0Ghz w/TRUE | Mobo: MSI P35 Neo2 FRI | RAM: Patriot 800mhz 4-4-4-12 @ 960Mhz 4-4-4-12 w/OCZ XTC Cooler | GPU: PowerColor HD 4870 w/Xigmatek Battleaxe | HDD: Samsung F1 1TB | PSU: OCZ GameXtream 700W | Case: Silverstone FT01 |
