Old October 4, 2008, 03:50 PM
Jon_di2's Avatar
Default Advice on opening a monitor
Ok So I'm trying to open up a lcd monitor, I'm fairly certain that it has a dead capacitor so I'm looking to figure out how to open it up. Its a 20 inch lcd, and I've taken off all the screws. I can lift the bottom of the front of the monitor off slightly but I can't seem to get it off any more then that. Should I try to force the sides off? Has anyone opened a monitor before?
EVGA780i FTW|Q9450@3.3|2x2GB Mushkin Redline 8000|GTX 260 Core 216 65nm|Corsair TX750|Antec 900|Acer 22|Antec Multimedia Premier|WD 640GB|Seagate 500GB|Logitech G15|Vista64
EVGA790i FTW|E8400@4.1|4x1GB Aeneon Xtune DDR3-1866|2xGTX 260 55nm|CM 750W| CM690|Viewsonic 25.5|Seagate 500GBx2|Logitech G5|Razer Lycosa|Scythe Kaze Master 5.25|Win7 & XP
Dell XPS M170|Pentium M @2.00|2GB DDR2 @667MHz|Nvidia GeForce Go 7800 GTX|120GB|17" WUXGA|XP32
Old October 4, 2008, 04:22 PM
CMetaphor's Avatar
Quadfather
I've opened many laptops before (but not many monitors admittedly). There are normally little plastic tabs that hold the parts together without screws, they should "pop" open one at a time if you take your time going around the edge of the monitor. I'd suggest using a small Flathead screwdriver to gently wedge it open. I'll get back to you with more details, I'm going to replacing the silver bezel of my monitor with a black one in the coming weeks so I'll let you know how it goes, hehe.
Old October 4, 2008, 04:29 PM
Jon_di2's Avatar
I found a video on youtube of a guy doing it :
YouTube - DELL LCD Momitor repair
Did exactly what he did and it worked. Thanks for the quick reply though. Prying the sucker off was the right idea!
Old October 4, 2008, 04:41 PM
Cptn Vortex's Avatar
My monitor has no more plastic casing lol. Its kinda easy to remove if I remember correctly.
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old October 7, 2008, 12:47 AM
Jon_di2's Avatar
Alright I'm way beyond the opening of the monitor, I've taken the mainboard out and de-soldered capacitors that looked no good and replaced them.... however I have found the problem. Its a very small black... capacitor or resistor (leaning towards resistor). It also had a magnet on one end...
Labeled:
6528
R1007
Any ideas what this is? (will post pics later if I can)
Edit: Haha forgot to mention the small black resistor (I think) is leaking green crap... and I assume this accounts for my monitors issues.
