Old September 7, 2008, 01:08 PM
Default E8400 temps
Guys quick question, finally got my rig going. What is the best software to read the temps on my E8400. The bios fluctuates between 25-28C on idle on water. I had installed coretemp which started reading more like 35-38C on idle, I found it high since i'm using a dual rad for just cpu.
Old September 7, 2008, 01:10 PM
Dwayne's Avatar
I think Realtemp is the best bet. The authour of the software seems to really know his stuff and provides support on the forum where you can find it.
Real Temp - New temp program for Intel Core processors - XtremeSystems Forums
Dwayne's Rig - Asus Prime Z370-A : i7 8700k : Corsair Vengeance 32 GB DDR4-3000 : Corsair RM650x PSU : Corsair H100i V2: Fractal Design Meshify C : EVGA GTX 1080 :
HTPC - GigaByte H67MA-UD2H : i3 2100 : 8 GB Mushkin Silverline Stiletto : Antec TruPower 550W : : Corsair H100 : Sapphire HD 6670 : Corsair 650D: Kingston 60 GB SSD Boot
Tablet - Samsung Tab A 10.1"
Wife's Rig - MSI GL72M 7RDX
SugarJ's Avatar
Make sure you're using Coretemp 0.99.3, that one has the correct TJmax values for all the 45nm chips. Earlier versions read 5 or 10 degrees high.
And I'm running at 26 deg idle on my loop.
Old September 7, 2008, 01:57 PM
RealTemp set to TjMax of 100
Old September 7, 2008, 02:00 PM
Dwayne's Avatar
I think coretemp set to 100 TJmax as well. There was supposed to be some resolution to the sensor measurement info during the Intel party a couple of weeks ago, but it just muddied the waters more it seemed. There is a lot of good discussion in the link I provided, as well you will find a link near the end to the newest beta, 2.77.
Old September 7, 2008, 02:55 PM
Well if I set TjMax to 100, both programs read 34-38C on idle.
Hm.. Some what high for it.
Old September 7, 2008, 03:00 PM
Thats perfectly fine.
You need to take into consideration your ambient temps as well.
Old September 7, 2008, 03:07 PM
Dwayne's Avatar
My temps at idle on my E8400 are about 40/30. I have a pretty consistent 10 degree split, though it gets closer as the CPU is under load. I have been running OCCT for almost 2 hours now and my temps are 52/46 clocked to 3.6 Ghz / 400 FSB voltage is Vid 1.25v and RAM at 2.1v.
Old September 7, 2008, 03:11 PM
sswilson's Avatar
Hmmmm.....
Mines an 8c split. I wonder how many other folks have the same issue. (Really thinking about lapping this puppy.... :) ).
Old September 7, 2008, 03:13 PM
Dwayne's Avatar
I can't afford to replace it at this time if I mess up the lap :) I am content that the high is still well within useable levels.
