Old September 7, 2008, 12:28 PM
Scart's Avatar
Default 5000+ BE or regular 6000+
My old 4200+ processor is really starting to limit me, so I'm thinking of a little upgrade as the am2 processors are pretty cheap now. I'm just wondering if the 5000+ black edition will offer more for overclocking and 20 bucks cheaper, or if it would be better to just get the 6000+ for 20 bucks more and 400 more mhz.
What do you guys think?
Old September 7, 2008, 12:32 PM
sswilson's Avatar
If previous AMD lines are any indication you'll get just as much (or more because of the unlocked multi) out of the 5000+ as you will out of the 6000+.
Their final offerings in a particular socket tend to offer the same performance as earlier chips, they're just binned higher.
Old September 7, 2008, 01:33 PM
geokilla's Avatar
Did you overclock your 4200+? Assuming you have a good chip, it should reach 2.7Ghz easily.
I've read that the 5000+ BE can get up to 3Ghz easily. However, is it worth it to spend like $70 on a new CPU? That's the question you gotta answer.
Old September 7, 2008, 02:05 PM
Scart's Avatar
I had overclocked it previously and i got it up to 2.64. Then my hard drive crashed and I really don't feel like messing with that again. I'm just gunna upgrade and then go from there.
And I only have a medium-sized cooler master hyper tx2 to cool it, so heat may prevent me from pushing the 5000+ too far.
Old September 17, 2008, 10:20 PM
Eagle Eye's Avatar
My 5000+ BE sits @ 3.2ghz since the day it come out of the box and that was with a simple multiplyer change to 16 and a bump in voltage 1.4125 in the bios runs smooth and cool on a TRUE. Also for 70 dollars you can't go wrong with that it will even chase down a phenom or 2 in certain situations.
