Old April 20, 2007, 09:31 PM
Tartan2007's Avatar
Default AMD Athlon XP 2000+ Palomino & Cooling
Hi All
I presently have the original heatsink & fan on my ASUS A7N8X-X Slot A (462) motherboard. Does anyone have any suggestions on what else I could use for cooling? Present temp is 44C, mainboard is 29C and hard drive is 34C.
Old April 20, 2007, 10:00 PM
Supergrover's Avatar
Thermalrights slk800/900 were champs, with a 92mm tornado fan they rocked. But IDK if you can find one nowadays maybe ebay. Or the for sale/ WTB sections
R.I.P.
Old April 21, 2007, 07:20 AM
Beermaster's Avatar
I agree with supergrover on the Thermalrights slk800/900
Grovian - *E4300@2.2ghz*Gigabyte DS3L*G.SKILL F2-6400CL5D-2GBNQ 3x1Gb*Sapphire HD4850 1GB*Raptor 75Gb*
Buggz - *E7200@2.9ghz*Asus P5Q*Patriot PC2-6400*eVGA 8800GTS 320gb*WD 160GB CaviarSE*
Lil-Grov Acer One*8gb SSD*WinXP pro
Tathar WIP*Q9550*Gigabyte EP45-UD3P*OCZ Reaper PC-8500 4gbX2*OCZ Vertex 120gb*WD 1TB WD1001FALS*BFG GTX275*
Old April 22, 2007, 02:18 PM
Misoprostol
Guest
Posts: n/a
Go water. lots of people are always trying to get rid of old water cooling stuff. D4 pumps, Swiftech MCW6000 blocks and heatercore radiators couldn't be cheaper. Check any BST you know of.
Old April 23, 2007, 08:54 AM
ebdoradz's Avatar
Thermalright SLK900 HS are great that what my mobile barton is cooled by, pair it witha tornado fan , and you can have a OC A-XP that idle @ 30C
Gigabyte GA-MA790XT-UD4P / AMD Phenom II x3 720BE @ x4/ Crucial Ballistic DDR3 / Sapphire 4830 512mb / Corsair 620W PSU / 2*80GB Seagate
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.7Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Fortron 450W PSU / 2*Maxtor 80Gb
AMD Athlon X2 4600+ 334th_Frenchie CPU's and Motherboards 10 June 8, 2007 09:50 AM
Countdown - HCF Folding team to the top 2000 pscout HardwareCanucks F@H Team 42 May 30, 2007 08:01 PM
AMD XP 2000+ Athlon Palomino Tartan2007 Overclocking, Tweaking and Benchmarking 7 April 15, 2007 08:13 PM
amd athlon 5600 cpu cooling asta1800 Troubleshooting 6 April 13, 2007 03:04 PM
