Old April 19, 2007, 06:09 AM
Default Is someone able to OC FSB higher than 300MHz on Kentsfield
Hi,
I will like to know if someone is able to OC the FSB higher than 300 MHz stable on Intel D975XBX2 mobo?
I did 395 MHz with TwinX Corsair 667 MHz but with OCZ (non-matched) PC6400 800 MHz I am not able to go higher than 300 MHz stable...at 8 X.
Do I need well match memory to push higher?
My goal was to have FSB at 400 MHz at 8 X!
Pushing the FSB give me more memory BW and MIPS for my CAD application...and I like that!
Any suggestions?
Intel Core 2 Quad QX6700 OC 3.6GHz
Mobo D975XBX2, 4GB DDR2 800 MHz Corsair TWIN X Dominator
4X 36GB Raptor in RAID 0 (on Intel controller with dual Boot Win32 Pro)
3X 360 GB Seagate No RAID (on Marvell controller for Apps, Paging and Back up)
EVGA GeForce 8800GTS Dual DVI- 2x Monitors 24'' 1920 x 1200
Water Cooling, Ultra X3 1000 Watts PWS.
ASUS Laptop G2S T7700 @ 2.4GHz
Old April 19, 2007, 03:19 PM
Fallen Folder
I don't have a badaxe but i have several quads running over 300 fsb.
x3210's and q6600's .. they range from 325 - 375 fsb ... the 2 at the high end are running on water.
All are 724 folding stable (eg near 100% load).
Q6600's on p5w64's the x3210's on ds3 rev 3.3
x3210s are 8 multi, q6600 are 9.
I haven't tried them without matched memory.
p5w64's are using 2x512mb crucial 6400 ... dont recall but i may have a mulitplier > 1:1 on these.
ds3 are running corsair 2x512mb 5400 ul 1:1
Old April 19, 2007, 05:50 PM
...this is what I think (with PC6400 memory), the key must be with well match memory!
Old April 19, 2007, 07:30 PM
Babrbarossa's Avatar
Does that board allow you to 'unlock' the memory?
psst, wanna see my binder?
Old April 20, 2007, 01:54 AM
Misoprostol
Guest
Posts: n/a
Bad Axe 2 should have no problem going over 300MHz FSB on a quad. What kind of cooling are you using on it? What kind of instability are you encountering?
I haven't used a bad axe 2 in a while, but iirc it was a pretty good Kenty board.
Old April 20, 2007, 03:29 AM
To answer Babrbarossa, I attached a picture of the option that I have with this board.
I have the Ultra Chill Tec electric cooler. I do not have problem with temperature...I monitor carefully with MemTemp.
When I cross the 300 MHz FSB...I can't post or if I post, Windows freeze or I started having error with Prime95.
With my TwinX Corsair at 667, I was able to go up to 395 MHz. But was stable and temp was at 65C (100% load) when FSB = 333 MHz and multiplier at 10.
Old April 20, 2007, 03:33 AM
I attached the CPU setting
Old April 20, 2007, 04:11 AM
Try cranking the CPU up to 1.55V - should be no problem with the TEC- won't even make it sweat.
Old April 22, 2007, 07:03 AM
Default ...new problem with 4GB of memory
I never try to crank the CPU voltage higher than 1.40.
I did try CPU voltage up to 1.55 volt and I was able to OC 9 X 333 MHz or 11 x 300 MHz with the non-matched OCZ PC6400 memory.
I compared the results of Sandra's Memory BW, CPU MIPS and MFLOPS and Super PI with the Corsair matched PC5400.
I concluded that a non-matched PC6400 800 MHz equal a good matched PC5400 667 MHz...Stable with Prime95 with Temp below 70 C. Too bad, I should know that to OC I should buy matched memory!
Now I have a problem: I did all my testing with only 2 sticks of 1 GB memory. When I tried to put back my two other Corsair sticks, the computer can't post anymore. I tried to reset everything at stock and still can't post.
I swap memory stick and same problem!!!
Is anyone encounter this problem before?
Old April 22, 2007, 07:10 AM
sswilson's Avatar
Did you try a c-mos reset? It sounds like one or more of your "enhanced" memory settings is beyond the abilities of your second set of memory.
WTB IDE Hard drive 40GB(or higher) belgolas Buy/Sell & Trade 6 February 8, 2008 09:45 PM
tighter timings or higher speeds thetallone RAM 5 July 6, 2007 07:39 AM
Chartered Semi in talks to move AMD to higher tech Babrbarossa Press Releases & Tech News 1 March 22, 2007 03:19 AM
Kentsfield and the 680i advice sizerkozak Overclocking, Tweaking and Benchmarking 15 February 26, 2007 01:37 PM
Kentsfield Review by HardwareCanucks Gav CPU's and Motherboards 0 November 8, 2006 09:53 PM
