Register Sweepstakes VB Image Host Members List LAN Calendar Search Today's Posts Mark Forums Read
LinkBack Thread Tools Search this Thread Display Modes
Old August 24, 2008, 10:23 PM
Level up: 64% Level up: 64% Level up: 64%
Level: 10 - 102 points to level up
Originally Posted by geokilla View Post
Can 65C to 70C really fry an egg? I'd think that it'll take a while to cook.....and the yolk in the middle wouldn't be like liquidity....Then again, I have no cooking experience whatsoever.
It's funny how the Extreme processors have a lower TjMax. 85C for a QX9770.
At that temperature the eggs will get eaten up by bacteria. It is below body (78 C) temperature. It will go rancid before it gets hard!
Paphman910
Old August 24, 2008, 10:27 PM
Jon_di2's Avatar
Level up: 22% Level up: 22% Level up: 22%
Level: 13 - 382 points to level up
I wouldn't let anything go over 70 degrees on full load... currently OCing my Q9450 to 2.85GHZ and my temp on Core 0 spikes at 66 degrees (the others are 2-4 degress less).
When I went to 3.0GHZ, my temps were spiking at 71degress... so I pulled back. Keep in mind though my heatsink isn't working properly, couldn't get all the stupid pushpins in on my OCZ Vendetta2
While I don't like going over 70 degrees I think that the cores spiking as high as 75 is fine. And when I say fine, I do mean probably not going to reducing the life expectancy of the processor too much
EVGA780i FTW|Q9450@3.2 w/OCZ Vendetta2|2x2GB OCZ SLI@800MHz|EVGA GTX 260 Core 216|Corsair TX750|Pioneer DVR-215DBK|Antec 900|Viewsonic 25.5|Western Digital 640GB|Seagate 500GB|Logitech G5|Razer Lycosa|Dual Boot Vista64 & XP32
Dell XPS M170|Pentium M @2.00|2GB DDR2 @667MHz|Nvidia GeForce Go 7800 GTX|120GB|17" WUXGA|XP32
Old August 24, 2008, 11:06 PM
Hopefully you get rid of those push pin soon and use the Thermalright bolt-thru kit soon!
Paphman910
Old August 25, 2008, 12:28 AM
MpG's Avatar
MpG MpG is online now
Level up: 42% Level up: 42% Level up: 42%
Level: 16 - 421 points to level up
Very interesting, now that I think about it a little more.
My version of CoreTemp and OCCT are both using a TjMax of 105 degrees for my QX9650. At idle, it's claiming two of my cores are at 23 degrees. That is, my chip was apparently 82 degrees away from thermal shutdown. But since the chip real TjMax is actually 95 degrees, that means the sensor technically thinks the cores are only at 13 degrees, which is well below my ambient temps. Just goes to show how inaccurate the sensors are, the further away from TjMax you get.
Conversely, anyone with a chip with a 100 or 105 degree TjMax, double-check your temp monitoring program, because if it was assuming 95 degrees, your chip might be hotter than you think!
QX9650 @ 4.038GHz (425x9.5) | Asus Formula Maximus | GTX280 (777/1620/1404) | Mushkin XP2-8000 Redline 2x2GB
Q6600 @ 3.6GHz (400x9) | MSI P35 Platinum | 8800GTS 640MB (700/900) | Mushkin EM2-6400 2x2GB
Old August 25, 2008, 12:34 AM
Jon_di2's Avatar
Paphman910
Haha ya, I bought it on friday, hopefully it gets here soon!
Old August 25, 2008, 05:04 AM
DK2's Avatar
DK2 DK2 is offline
Level up: 30% Level up: 30% Level up: 30%
Level: 13 - 340 points to level up
Paphman910
Hey hot stuff, go see a doctor asap, before it falls off!
(37C / 98.6F) no idea where you got 78C from.....
Custom Armor case / Gigabyte X48T / Q9550 3.2GHz / Coolit Elite CPU Cooler / OCZ Platinum 4GB DDR3
EVGA GTX 280 SSC / 2x VelociRaptor HDD RAID0 / 2x HDD 750GB / 2x Samsung DVD Burners
Razer AC-1 Sound card / 6600GT video card / ToughPower 850 Watts / 24 & 20 inch Monitors
My Pet Monster
Forum Jump
Search this Thread:
Advanced Search
