I have 2x2gb kingston ram and a e8400 cpu. My problem is i cant decide which motherboard to use. I have: GIGABYTE - Support - Motherboard - BIOS - GA-P35-DS3L (rev. 2.0) and ASUSTeK Computer Inc. I bought the Gigabyte from a user on the forums and the P5K i won in a bet with a friend lol (long story). The boards look like they have alot of the same features to me. Now i know my ram isnt all that great but which board would be better for OC my CPU? Thanks in advance for any input you guys (and girls) may have. |
I have a Asus P5K still and I OCed my E6550 to 3.5Ghz no problem and got 3.9GHz with my E8400 on that board, going to OC my E2140 next on that board once I get a HSF for it. Both boards are good I think, never had a GA-P35-DS3L. But a lot of people here say there great. flip a coin and pick that way..
__________________ Intel Quad core X3210 OC@ 3.4GHz ,Coolmaster Hyper 212 , Asus P5Q-E, G skill F2-8500CL5D 4GBPK, eVGA 9800GTX KO 512MB, WD 750GB HDD 16MB cache sata II, CM 690 with 6 120mm fans, Corsair HX620-watt power supply, Pioneer DVR-112, OS Vista Ultimate 32bit Second Rig for FOLDING. Intel E2140 OC @ 2.4GHz, Asus P5K, G.Skill PC6400 2GB, BFG 8800 GT OC 512MB, Maxtor 40Gig HDD, Thermaltake 550W PSU, XP Pro heatware |
The Gigabyte I have to agree is a nice board, since its a newer chipset (p45) been designed to perform better than its younger brother. It comes down to what kind of video card you gonna use, if its dual then you have no choice but Asus, if its a single card, the gigabyte hands down.
miggs, they are both P35. If they both allow the same overclocking you should take a good look at what you want and what you need and select between the two. The P5K(vanilla) can use a P5KR BIOS for AHCI mode on the ICH9 SATA ports, it can do CF, has FireWire and eSATA. The DS3L has more PCI-e 1x slots, has parallel port, PS/2 mouse, optical audio. DS3L has external serial port but P5K has onboard serial header as well. P5K has five internal SATA ports while it looks like the DS3L only has four. I personally like the cooling around the CPU socket of the P5K more than the simple NB HS the DS3L has. But yea, in the end I think you should just pick the one with the features you want most.
__________________ Phenom x4 9950 BE, Gigabyte MA790GP-DS4H, 2x2GB G.SKILL F2-8000CL5D-4GBPQ 250GB 7200.10/640GB&500GB 7200.11 'Cuda, Samsung SH-S203N/Pioneer DVR-112D Radeon HD 3850 256MB, 22" Acer X223W Corsair TX750W, Generic(?) ATX fulltower case (6x 5.25"/9x 3.5") Sansui G-4700 receiver +2x 60w spks/Yamaha YST-M7 |
Go for the P5K. Why? Because I've always bought Asus over the Gigabyte - a superstition thing. Neither board is "better" than the other really.
__________________ Intel Q9450 @ 3.8GHz 1.33V | Asus P5Q-E | 2 x 2GB OCZ Reaper HPC DDR2-1066 2.18V @ 1144MHz | WD3000GLFS VelociRaptor | 2 x WD6401AALS Caviar Black | WD5000AAKS Caviar SE | Antec 1200 | PCP&C Silencer 750W | 512MB Radeon 4870 790/4000 | 2 x LG L222WT-BF | Auzentech Prelude X-Fi | Logitech Z-5500 THX 5.1 | Logitech G15 2nd Gen. & G5 | Thermalright Ultra 120 Extreme | Vista Business SP1 64-bit Heatware --> 214-0-0 |
I've owned both. Several DS3Ls actually. The P5K, as mentionned MacJunky has more features. But the DS3L was the king of the oc, with an E8400 @ 4.2GHz and a Q6600 @ 3.6GHz. Need features? Asus. OC'ing? Gigabyte. Otherwise, flip a coin, and sell the other.
__________________ Main: GA-X58-Extreme - i7 920 - TX750W - Raptor - 3Gb DDR3-1333 Triple-Channel - GTX260 SLI'ed - TRUE - P182 HTPC: M3A78-EM - 5000+ X2 - HX520W - 'cuda 1Tb - XP2-5300 2x512Mb - 9800GT - SI-128 - Prelude - Moneual 932B |
| Thread Tools | |
| Display Modes | |
