| Quote:
But his stuff isn't bad.
__________________ CSE: Lian-Li PC-A70 MOB: Biostar T-Power I45 CPU: Intel C2D E8600 @ 4.3ghz RAM: 4gb g.skill pc2-8000 GPU: XFX 8800 GT Alpha Dog Edition PSU: PC Power & Cooling 750w Heatware: My Heatware |
Ceramique is good, but messy. MX-2 is all around the best TIM out there. Use it. (unless you want to keep it for yourself....)
__________________ The Vortex H20 Case....not sure what to call it DFI X38 LT Xeon X3210 @ 3.2GHZ 1.30V PNY 9800GX2 (750/2200) 4GB Corsair Dominator 2x2gb kit DDR2 1066 5-5-5-15 2.0V Ultra X3 1000W PSU HT Omega Striker 2x500GB Hitachi RAID 0, 250 Seagate Sharp 32" Aquos 1080p Benq W500 1080i Pojector. Watercooling: Loop 1 - D-Tek Fuzion Quad Nozzle Bowed, MCR320+Zalman ZM-F3 Fans, MCP655, MCRES Micro. Loop 2 - DB-1, DD 9800GX2 block, MCW30, MCR320, tLine res. |
I'm using MX-2 with his permission. The Ceramique apparently sets up quite glue like after a couple of heating cooling cycles and can be difficult to remove if needs be. As I expect if this has to come off I'll be doing it so I'd rather not make more work than is necessary
__________________ Obsolescence is just a lack of imagination. |
| Thread Tools | |
| Display Modes | |
