Old August 20, 2008, 07:52 PM
3oh6's Avatar
Hardware Canucks Reviewer
Default Gigabyte GA-EP45T-Extreme Motherboard Review Comment Thread
Here it is boys and girl, I am sure there is one here somewhere, the Gigabyte GA-EP45T-Extreme! One of the most feature rich motherboards available right now and a very solid performer. Unfortunately it is also a P45 based motherboard so it comes with its flaws.
Read all about the good, the bad, and the ugly...the ugly referring to the pink & green memory slots
Feel free to post any questions/comments/concerns about the board, the review, or my lack of personal hygiene here and I will do my best to assist in addressing them.
Old August 20, 2008, 08:31 PM
CTA's Avatar
CTA CTA is offline
interesting... i dont know that it has some bad problems... i think its not bad deal for water cooling set... but i prefer air cooling to avoid lots of problem... eeks...
just curious why not show the result with other competitive [same-class] mobo?
Old August 20, 2008, 08:53 PM
belgolas's Avatar
I don't know about you but I love copper heat sinks. Man I love the looks of that board. Now if only you had a copper CPU heat sink and GPU heat sink and it would look sweet.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Old August 20, 2008, 11:31 PM
Cptn Vortex's Avatar
Not bad not bad, but I am still a DFI guy through and through.....
The Vortex H20
Asus X99-E WS/USB 3.0
i7-5820K
3 x GTX 1070
4x4GB Corsair LPX 2666MHZ
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old August 21, 2008, 05:06 AM
bojangles's Avatar
After reading the review, Gigabyte could have tried a bit harder on this one. Solid vdroop, but the board is really ugly and all the SATA ports could have been rotated instead of just 2. I'll keep my fave P45 motherboard on the P5Q series.
Old August 21, 2008, 05:09 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Actually, I am in the same boat as Jody. When these intricate heatpipe solutions are NEEDED, then I will welcome them but the P45 is one of the coolest running chipsets to date and on this board it is coupled with a heatsink what doesn't conduct heat in the way it was meant to.
Old August 21, 2008, 02:09 PM
3oh6's Avatar
the water cooling would be fine, overkill but fine, it is just that the watercooling doesn't even cool anything. the cooling fins between the base where the chipset is contacted and the actual waterblock receives none of the heat because cooling fins don't transfer heat, they dissipate it. it is a ridiculously well built setup but the major design flaw negates everything good about it. with that said, Gigabyte might have already corrected their flaws it seems with their new X58 board...
GIGABYTE shows us its X58 Extreme mobo in Taipei :: TweakTown
it doesn't appear to have between the real base and the chipset...just that huge chunk of copper and the block directly on the chipset. it is kind of hard to tell from the pictures and the one photo almost looks like fins but it also looks like it could simply be a solid chunk of copper. if Gigabyte could have made that happen with this board, all my complaints would be 100% rescinded.
**edit** ah man, i just zoomed in on the one photo and sure enough, fins in-between the chipset and the base of the waterblock/hydra cool mount. sorry guys but that just continues not to make sense. **end edit**
as for the comparison to other motherboards question, that is a decision we made when we designed our motherboard layout. showing the difference between different boards with the same chipset showing 1-3% difference in performance and saying one is better than the other based on the results seems like a futile exercise in our opinions. instead, it allows us to focus more on the features and come up with interesting benchmark comparisons between "stock" and overclocked like we did in this review. it really was interesting to see what simply adding the XMP memory could do for the average user who wouldn't even know how to overclock if they wanted. it really was startling how much performance is gained on P45 with high end memory versus what a generic kit might run at.
Old August 21, 2008, 02:29 PM
Eldonko's Avatar
I think "the EP45T-Extreme has a drawback for almost everything it does positively in the overclocking section" sums things up quite well for my uses. Lucky for giga fancy looking stuff with loads of features probably sells better than a top clocker. Giga sure likes their heatpipes eh, lol.
Great review.
Old August 21, 2008, 02:42 PM
Dr_BenD_over's Avatar
Fallen Folder
Pink ram slots.... I'll leave it at that.
All's well that's Haswell
Old August 21, 2008, 03:19 PM
SugarJ's Avatar
You mean like this?
http://www.hardwarecanucks.com/forum...ransplant.html
