Old August 20, 2008, 07:06 AM
CMetaphor's Avatar
Quadfather
Default 790Gx - HTT 3.1 and 45nm Phenoms.
AFAIK the 790GX/SB750 combo motherboards that are out emerging on the market now ARE compatible with the upcoming 45nm Phenoms. However, other than this article : techPowerUp! News :: HyperTransport 3.1 Specifications Emerge, 45 nm AMD CPUs Support it
Does anyone know if these 790GX boards will for sure support the new Hypertransport 3.1 specification?
Old August 21, 2008, 09:11 AM
according to Tom's it 'should'
http://www.tomshardware.com/news/Hyp...sion,6179.html
AMD Phenom II 940 @ 3.0Ghz | OCZ Vendetta II | Gigabyte GA-MA790GP-DS4H 790GX/SB750 | 2x2gig Musking Redlines 5-5-5-18-24 T2 | XFX 8800GT XT 512MB @ 702/1023 | WD Raptor 36,74gig | OCZ GameXtreme 850w | Cooler Master Cosmos 1000 | Samsung Syncmaster 2443BW | Logitec x530 5.1 | Windows 7 Home Pre.64-bit
Old August 21, 2008, 09:17 AM
CMetaphor's Avatar
Quadfather
"Should" isn't all that reassuring. I'm hoping to upgrade in the next couple weeks and will need a board that supports the 45nm AM2+ Phenoms and hopefully their successors, the AM3's. It seems that most sites agree that the bandwidth won't be a problem but whether or not a bios upgrade will be necessary/possible is up in the air still. I'll have to keep thinking about it and searching for more news.
