Originally Posted by CntdwnToExtn i've been waiting for this to happen.
can't believe they lasted this long. |
Well I gather you don'T like VIA chipsets - To be fair, yes VIA chipsets have had a bad reputation over the years due to its crippled PCI bus and the many problems people had with slow disk transfers and crackling - however, I've ALWAYS used VIA chipsets sine the KT133 and never had ANY issues, my system was rock solid. The chipset KT133/A was decent, of course there was still a problem with PCI bandwidth but you could get around it. the KT266 and above were bad from what I recall. My recent motherboard was using the K8T890 chipset and it ran rock solid, and didn't notice ANY of the bandwidth issues whatsoever, no crackling no nothing - there was more complaints over NVIDIA chipsets exploding, failing, screwing up, etc than VIA at the time - given NVIDIA's failure rate and reputation with its chipsets I would have gladly gone VIA over nForce at the time - if only VIA had admitted and done something about the sustained PCI bandwidth issue, it would have done better. Now with VIA gone, and NVIDIA possibly leaving (rumor), guess we'll be stuck with AMD chipsets :D :D :D
