Originally Posted by MpG In all seriousness, you can expect a pretty hard time getting that Q9550 stable at 500FSB, assuming it even boots. Quad-cores simply don't handle high FSB's very well. But even 450FSB will let you run that memory at 1800MHz, which is still pretty damn fast. |
Agreed. I don't think you'll get to 500FSB unless you employ water cooling. With my Q9450 I can do 450FSB but the temperatures are very high even with a Thermalright Ultra 120 Extreme. And by the time you're above 400FSB you will need to increase the CPU voltage (and chipset among other things) exponentially.
