Register Sweepstakes VB Image Host Members List LAN Calendar Search Today's Posts Mark Forums Read
LinkBack Thread Tools Search this Thread Display Modes
Old August 7, 2008, 06:46 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Default ASRock P45R2000-WiFi Motherboard Review Comment Thread
Hey guys, I apologise for the delay in posting this but I am away on vacation right now. Please post your questions or comments about the review and Ill try and get back here when I can.
Hockey Mod at your service
Old August 8, 2008, 01:32 AM
1Tanker's Avatar
Level up: 23% Level up: 23% Level up: 23%
Level: 14 - 449 points to level up
All-in-all, not a bad showing for an ASRock (budget) board. Nice to see vCore/vDIMM adjustment...and in number, not low/med/high. Also surprising to see GTLref adjustment. With the low price of the Wolfdale's now(~$170/E8400,~$130/E7200), a pair of uber-cheap HD38x0's..4GB DDR2/~$90..and a cheap-arse HDD(WD640/$75) and good PSU..you could put together a kickin' gaming rig on the cheap.
Old August 18, 2008, 05:19 PM
Eldonko's Avatar
Just saw that ASRock released 3 new BIOSs since this review so I am going to give BIOS 1.6 a try.
Old August 25, 2008, 02:15 PM
Eldonko's Avatar
Don't know what they changed but I can say the 1.6 BIOS is totally different from the one used in the review (1.3). Seems I can use some mem dividers effectively now and first impressions are positive. Need to do more testing so I will update later. :)
Old September 4, 2008, 03:02 AM
Level up: 24% Level up: 24% Level up: 24%
Level: 10 - 214 points to level up
Nice review. Damn those PCI-e slots are very close and would rule out a lot off after-market active coolers for Crossfire and that little cards looks very awkward in between the PCI-e slots.
Wow I thought my vDroop ripple was big at 0.4 but that is quite a bit larger, would this contribute to OCCT failed runs at lower Voltages of say 1.4v?
Q6600@3.15Ghz|CNPS9500|P5WDH|4GbCrucial4-4-4-12|Sapphire 4850|OZC GameXtreme 700|XP64
Old September 4, 2008, 09:29 AM
Eldonko's Avatar
I must say the 1.6 BIOS is really improved over past versions. It is not perfect but at least my mem works now.
Yeah droop is high, plus the board under volts anyway. If I set 1.4v in BIOS under load I would probably get more like 1.31-1.32v load, which would be iffy for 4Ghz. At least the vcore line is pretty stable...
Forum Jump
Search this Thread:
Advanced Search
