Old August 4, 2008, 11:39 AM
Default E8500 Stuck temp
Hi,
I seem to have stuck temps on my new 8500,and i now know from reading various forums that this is a common problem.
Realtemp reads core 0 at 36 which seems to have the stuck temp,core 1 seems normal in the high 20s,everest reads them 10 degrees higher and cpu at 33.
I ran orthos and both temps did go up,but core 0 never below 36.So should i rma to ncix while i still have a few days left,or is this a good processor,i cant decide?
thanks for any help.
Asus P5E X38
E8500?
2x2GB Mushkin Ascent
BFG 8800GTS 640
Creative X-FI Sound
150GB Raptor
500GB Seagate 7200.11x2
OCZ 700W Power Supply
Vista 64
Old August 4, 2008, 11:42 AM
Chos3n's Avatar
My temps are 39 - 41 degrees IDLE and 58 load...
But I think the new architecture of the wolfdale isn't precise with the temp tools... Even though I used RealTemp.
Maybe a sensor is broken on your CPU ...
System | Ragnarok
Case Antec 900
PSU Corsair TX750W
CPU Intel Core i7 2700K 3.5GHZ
Motherboard ASUS P8Z68-V
Memory Corsair Vengeance Blue 8GB 2X4GB DDR3-1600 CL9-9-9-24
Video Card EVGA GeForce GTX 780
Sound Card ASUS Xonar DX
Old August 4, 2008, 11:44 AM
Hi,
These are my idle temps with core 0 temp sensor stuck at 36 degrees.
Asus P5E X38
E8500?
BFG 8800GTS 640
Creative X-FI Sound
150GB Raptor
Vista 64
Old August 4, 2008, 11:52 AM
Chos3n's Avatar
Most of the apps run on only one cores anyways, try to run WPrime which is design for multi-core CPU.
System | Ragnarok
Case Antec 900
PSU Corsair TX750W
Old August 4, 2008, 12:11 PM
Darn,dont have prime only orthos,maybe i should rma it,ust curious what do your cores run at.
Asus P5E X38
E8500?
BFG 8800GTS 640
Creative X-FI Sound
150GB Raptor
Vista 64
Old August 4, 2008, 12:18 PM
misterlarry's Avatar
On my E8400 I've got one core that doesn't read anything until it gets up to 41 degrees C. No problem with the cpu though and I don't think that anyone will rma for that reason alone.
Welcome to HWC anthony!
Asus Z97-A - Intel i7 4790K @ 4.0 GHz - Corsair H80 CPU Cooler- 4x8 GB G.Skill Ares DDR3 2400 - Zotac GTX1050 Ti Mini 4GB
1x240 GB Mushkin Chronos Enhanced SSD - 1x500 GB Seagate Hybrid Momentus - 1X2 TB Western Digital Green - Pioneer DVR-212D - Antec P182 - Rosewill Photon 850 - 2X24" Acer G246HYL - Windows 10 Home 64 v.1083
The world is your oyster. Shuck away my friend, shuck away!
Old August 4, 2008, 12:43 PM
burebista's Avatar
What unclewebb says about Wolfdale sensors?
So, fire up Orthos/OCCT and see your load temperatures. If their are ~equal you're fine.
Old August 4, 2008, 12:48 PM
yycraven's Avatar
Are you using realtemp 2.70 I find this is more for the wolfdale.
Old August 4, 2008, 12:54 PM
hi,
When i run te diagnostic core o sensor movement=0
core 1 sensor movement=4
Both cores reach 37 degrees in a few minutes of orthos an as always core 0 goes back to 36 and core 1 back to the high 20s.
i have not overclocked yet until i think i dont have a dud chip.
thanks.
Asus P5E X38
E8500?
BFG 8800GTS 640
Creative X-FI Sound
150GB Raptor
Vista 64
Old August 4, 2008, 12:55 PM
Yeah i downloaded the latest realtemp.
Asus P5E X38
E8500?
BFG 8800GTS 640
Creative X-FI Sound
150GB Raptor
Vista 64
