Old August 3, 2008, 09:22 PM
Default 100$ Processor...
Hi.
I have ~100$ budget to get a processor, ive been looking at the e2160's and e4xxx's. I do game btw. Which processor do you think would be best for me?, im gonna slap on a aftermarket cooler on it to oc it too.
Thanks
-Copper
Old August 3, 2008, 09:32 PM
MAC's Avatar
MAC MAC is offline
Associate Review Editor
I wouldn't get the E2000 series since the 1MB L2 cache is a pretty serious bottleneck in various games.
The E4000 series is good, but the cheapest one I could find is a $120 E4600, and at that point it becomes a little silly not to spend the extra $5-10 for an E7200, which is the best Bang for the Buck chip on the market.
Old August 3, 2008, 09:38 PM
SugarJ's Avatar
For that price range, the E2180 or E2200 is your choice. The E2200 is around $85 plus tax on pricecanada.com.
I couldn't find E4500's for under 130.
I've built a few business systems with the E2180, it's ok and I've heard they have a fair amount of headroom in them for OC, but I haven't tried twisting any of the ones I built.
Old August 3, 2008, 10:00 PM
yycraven's Avatar
What is the rest of your system contain, hardware specs of your computer.
If you can save another $50 I would get the E7200.
other wise there is this cpu
http://www.ncix.com/products/index.p...ufacture=Intel
Old August 4, 2008, 09:17 AM
JD JD is offline
I'd say E7200 too. Spend the little bit extra and get something half-decent. It's 45nm too so it's already 5-10% faster than the 65nm counter-parts, plus the added L2 cache. And best of all it should run cooler so you can OC it even more
Old August 4, 2008, 10:34 AM
My other specs are...
GTX 260
750i mobo
2gb 800mhz ocz ram
Old August 4, 2008, 11:24 AM
MAC's Avatar
MAC MAC is offline
What resolution do you game at?
Old August 4, 2008, 11:40 AM
1280x960
Old August 4, 2008, 11:56 AM
MAC's Avatar
MAC MAC is offline
Ah, so a fairly low resolution.
An overclocked E7200 is definitely what you need not to severely bottleneck your new system.
Old August 4, 2008, 12:01 PM
yeah, i know its low...I dont have enough cash to replace my old CRT screen yet...
D:
thanks, btw is the stock cooling on it fine?
edit: I dont plan to oc over 3ghz.
