Old August 1, 2008, 04:42 PM
Default 4 pin power enough for QX9650?
Just bought a new Asus P5E- Deluxe Motherboard with a QX9650
turns out the motherboard's CPU power plug is broken
the bottom 4 is alright
but the top left has 1 pin that is messed up
As a result
i cannot plug in the 8 pin CPU power chord in properly no matter how i try
I can only plug in 4 pin
Already called up ASUS for an RMA
but does it make a difference 8 pin vs 4 pin?
would i be able to run the QX9650 just on the 4 pin?
I really don't want to wait any longer for this computer to be built
Old August 1, 2008, 04:59 PM
Cptn Vortex's Avatar
Yeah 4 pin is fine. Only really need 8 if you are heavy into Overclocking.
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old August 1, 2008, 05:02 PM
SugarJ's Avatar
Is this the system where you thought the Enermax PSU was toast because it was giving you short code beeps?
Chances are that the broken connector on the mobo was shorting out the PSU. Do you really want to put a $1100 CPU into that board? I sure as hell wouldn't. But it's your money.
Old August 1, 2008, 05:15 PM
yeah this motherboard ****** up my PSU
i had to go to the PSU distributor today in my city to get an replacement
and now
the i prob have to wait 3 weeks for this motherboard to be mailed back to me fixed
holy crap
Old August 1, 2008, 05:20 PM
Do not run a QX on a 4 pin plug for the love of god.
Your gonna put a $1200 cpu and rely on that?
Might as well buy an asrock board for it.
Old August 1, 2008, 05:25 PM
3.0charlie's Avatar
I would never install my QX9650 on a defective board....
Hydro-Quebec is salivating...
Old August 1, 2008, 05:27 PM
magictorch's Avatar
Better to wait three weeks than loose a couple of thousands worth of gear if you decide to OC. I'm not sure i would trust a board with a broken 8pin connector. Never heard of a broken connector though.
I could babysit that cpu for you till its ready for its new home.
Anyway in that time you might decide that you want the mighty rampage extreme
Old August 1, 2008, 05:37 PM
SugarJ's Avatar
Lol, I just bought an Asrock X48TurboTwins from Eldonko. CHEAP! Don't like the 24pin connector placement though. I'm gonna have a hell of a time hiding that cable.
@Howdid, what I was getting at is that your PSU was probably fine, it was the Mobo causing the problem all along. If that connector was shorting, it still will short whether there is a 4-pin or 8-pin plug in it. I wouldn't put an E1200 in that board right now, let alone a QX9650.
Old August 1, 2008, 05:46 PM
wow
i called ASUS technical support at 6 pm today
they made me wait 1 hr and 30 min to get to a guy
who pretty much yelled at me and thought that i was a noob who didnt kno jack
He try to convince me that i was wrong by telling me he has never heard of a messed up CPU power pin b4
and he transfered me to the RMA department
which made me wait for 1 hr
then somebody picked up
told me to hold
and i waited for like 30 more min
what a piece of crap ASUS
will never buy their brand again
