well, with some help of another top clocker...AKA a slap in the face, i found out you can mount the MCW30 directly to the x48 IHS. you just need to remove the plastic spacers and angle the bolts out a slight bit...but it works and works well. as suspected in the review and demonstrated by the nylon washer trick lowering temps drastically...going direct contact lowers them a whole lot more. here is a photo of the block and the accompanying MC14s added for MOSFET cooling of the CPU and NB PWM...
the result, a NB temp that doesn't cross 35C in 23C ambients during a 32M run at 600FSB with 1.75vMCH
needless to say, this opened the door for all kinds of possibilities, including 600FSB 5:8 stable at tRD 8 (Performance Level 8). there isn't another X48 board out there that is capable of this kind of performance.
click for full size including memset & voltages
unfortunately though, this also means that the stock heat pipe assembly that was initially thought to be decent, really does hold Rampage Extreme back...when will they ever learn? heat pipe roller coasters hinder cooling...end of story.
