Old July 30, 2008, 06:51 AM
Chos3n's Avatar
Default E8500 Wolfdale Temp
Hello everyone,
I just received my E8500 CPU yesterday, so I installed it with the stock CPU and OCZ Silver. First thing I noticed, the heatsink is half the size of my E6600 and doesn't have a copper base. So, anyways I thought since it's the new 45nm tech, it wouldn't matter. After messing around in the bios and get the multiplier to 9.5 ( N/2 Force option, remember that) I booted Windows Vista, it booted super fast, and I noticed the difference right way. But then I ran Core Temp and my IDLE temp was 49 - 52 degrees... I find that a bit hot for my case (Antec 900). I can't remember my temps on my E6600, but I don't think they were at 50, rather 38 ish.
I don't OC, but if heat begins to be an issue I will get another heatsink ASAP.
Is it normal ?
System | Ragnarok
Case Antec 900
PSU Corsair TX750W
CPU Intel Core i7 2700K 3.5GHZ
Motherboard ASUS P8Z68-V
Memory Corsair Vengeance Blue 8GB 2X4GB DDR3-1600 CL9-9-9-24
Video Card EVGA GeForce GTX 780
Sound Card ASUS Xonar DX
Old July 30, 2008, 07:08 AM
1Tanker's Avatar
Originally Posted by Chos3n View Post
Hello everyone,
Is it normal ?
Yeah, Wolfdale thermal-sensors are all out of whack. I went from an E6600 to an E8400, and i was disappointed in temps as well.. but yeah, the stock HS/F they ship with them is a joke. If you have any intention of overclocking...definitely get an aftermarket HS/F. Nothing to be concerned about.
Old July 30, 2008, 07:11 AM
Chos3n's Avatar
Even though, 50 degree, on 10 - 15% CPU Usage... that's scary...it's also summer but ... I might save some bucks and go with another one. The new heatsink is so small!
System | Ragnarok
Case Antec 900
PSU Corsair TX750W
Old July 30, 2008, 07:15 AM
1Tanker's Avatar
Ummm...you lost me... you might get another what?
Old July 30, 2008, 07:35 AM
3.0charlie's Avatar
Don't use Core temp with the 45nm chips. Use Real temp: Real Temp - CPU temperature monitoring. And please do install an aftermarket HSF... the stock Intel sucks.
Hydro-Quebec is salivating...
Old July 30, 2008, 07:44 AM
Chos3n's Avatar
CPU! nah, a heatsink (aftermarket)
Now I think of something... I was so eager to try it out, I think I didn't remove the thermal paste on the heatsink and I just applied my OCZ Silver... so if the Intel Stock Thermal paste is still present with my OCZ Silver... this might cause the heat problem...
EDIT: Ok I will try that new program aswell.
System | Ragnarok
Case Antec 900
PSU Corsair TX750W
Old July 30, 2008, 07:49 AM
Mibs's Avatar
That's odd, Last time I installed a 45nm it came with the usual Intel hsf.
Intel C2D E6750 @ 3.52 GHz // EVGA 680i SLI Rev. A1 (P31) // 4 GB OCZ Platinum 800 MHz 4-4-4-15 // PC P&C Silencer 750 Quad // Antec P180 // EVGA 8800 GTS 512 // Samsung Syncmaster 226bw 22" LCD
WC Loop: D-Tek Fuzion V2 // Danger Den Maze 5 // Swiftech MCP655 // Swiftech MicroRes // Thermochill PA 120.2 + 4 x Noctua NF-P12
Old July 30, 2008, 08:17 AM
Chos3n's Avatar
It did came with a stock intel hsf, but it's a half size version of the E6600 cooler.
System | Ragnarok
Case Antec 900
PSU Corsair TX750W
Old July 30, 2008, 09:35 AM
Chos3n's Avatar
Ah, I might just go grab a new heatsink, any suggestions?
System | Ragnarok
Case Antec 900
PSU Corsair TX750W
Old July 30, 2008, 09:56 AM
SugarJ's Avatar
If you're not going to overclock, grab a Arctic Cooling Freezer 7 Pro. DC has them for under $20.
If you are going to overclock, look at the OCZ Vendetta 2 or Xigmatek HDT-S1283 for under $40, or the always popular Thermalright Ultra 120 Extreme for around $60 plus a fan.
I personally have a Scythe Ninja Copper which I've had great results with (idle 28deg, load 39) on an E8400 at 4.0Ghz, but you gotta like the look of copper.
