-   -   Just Curious (http://www.hardwarecanucks.com/forum/cpus-motherboards/8794-just-curious.html)
blogz101 July 24, 2008 01:37 PM
Just Curious
Is OCZ RAMS good?
Does the Asus Rampage Formula support/compatible with OCZ?
Is the RAM:4GB OCZ DDR II 1150MHZ PC2-9200 FLEX XLC LIQUID CONVECTION RAM
compatible with the Asus Rampage Formula?
links
LU Computer
JD July 24, 2008 01:48 PM
Yeah OCZ is alright though most people on here are going to recommend Muskin.
Unless your pulling some extreme overclocks, you don't need PC2-9200 RAM.
You could post here: OCZ Forum - Powered by vBulletin if you want to be 100% sure it'll work. I don't see why it wouldn't though.
-n7- July 24, 2008 06:01 PM
That's some extremely nice RAM.
Drawbacks of it would be:
- fat & tall heatspreaders (cannot do 8 GB, issues with clearance in some situations)
- price
I'd also say don't buy that if you don't intend to heavily overclock & tweak things in the bios.
That kinda RAM isn't meant for a basic user; be prepared to mess around to get its rated speed or better set up stably.
If those issues aren't scaring you off, go for it.
I wouldn't buy it due to the heatspreaders & price, but otherwise it's my kinda kit :)
calvary1980 July 24, 2008 06:19 PM
you should shop at NCIX they are only $68 AR even without the Rebate they are cheaper. and you shouldn't have problems installing 4 of them but no promises.
- Christine
Tazer-[X] July 24, 2008 10:19 PM
Well, a brand name is all that it is. Its hype, I bet, in a little while, that will change on whats 'kewl'. Just like a PSU, its a matter of who screams the loudest and how many follow him and say, yea, I beleive him coz hes 'kewl'. Honestly, Kingston will do just fine. Especially The HyperX. And apparently, DDR3 HyperX is gonna be FAST with a <H1> F
calvary1980 July 24, 2008 10:36 PM
Corsair is good because there units use high quality components and are inexpensive the 450VX for example has a Hitachi Primary that should be in a Power Supply twice it's price range, there Power Supplies are manufactured by the 2 best companies Seasonic and Channel Well Technology. it has nothing to do with Trend.
- Christine
JD July 25, 2008 09:58 AM
AFAIK Kingston isn't all that popular amongst enthusiasts for whatever reason. Usually HyperX is overpriced too since it's not stocked as much as OCZ/Corsair/Mushkin.
There obviously must be a reason to it though other than pure hype. Crucial has used to be all the hype but they've had some issues as of late.
Eldonko July 25, 2008 12:24 PM
I disagree, brand name is very important for memory.
DK2 July 25, 2008 12:34 PM
Heat spreaders fell off my DDR2 Gold's, so now they just kind of hang there by the clips.
They still work though, and I never had a problem with them.
The whole thing is going into a new case soon anyways so maybe I'll fix it then, or just rip them off, f'it. :biggrin:
Mibs July 25, 2008 12:46 PM
OCZ is a decent brand. I've had this kit for over a year, and a lot of others I've seen have it too. Like somebody else said, Mushkin seems to be pretty popular around here lately. I almost bough myself a kit of Ascents earlier.
