Old April 9, 2007, 11:50 AM
magictorch's Avatar
Default good 939 motherboard and case for opteron 165
Hi all,
Any ideas on a good 939 ATX motherboard for overclocking an opteron 165 to about 2.4ghz? Do they have any 939 micro-ATX boards that will do the job? Whats a good case for the ATX board....looking at around $300 max for case and board.
cheers,
magictorch
Old April 9, 2007, 12:00 PM
BALISTX's Avatar
As for a motherboard I recommend the DFI LANParty UT NF4 SLI-DR - $156.88 at Direct Canada
I recommend this case Coolermaster Centurion 534 ATX Tower Case - $5292 at Direct Canada
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old April 9, 2007, 12:06 PM
werty316's Avatar
$5292; that is one expensive case
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
Old April 9, 2007, 12:34 PM
sswilson's Avatar
Heh......
Yeah, it's a bit pricy, but it guarantees an extra 100 mhz on the OC..... :)
The DFI's did a wonderful job of OC'ing S939 procs.
Where did you get your hands on an opti?
Old April 9, 2007, 12:35 PM
Eldonko's Avatar
Hardware Canucks Reviewer
I agree, DFI Ultra D, SLI, or Expert are the best 939 ocing boards.
Old April 9, 2007, 12:45 PM
sswilson's Avatar
I dropped you (magictorch) a message in the other thread relating to this.........
Greenlyph here in hfx has the ultra-d's in stock for around $150.
Old April 9, 2007, 12:50 PM
BALISTX's Avatar
That is one expensive case LOL. It's supose to be $52.92
I'd get that Ultra-D for $150
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old April 9, 2007, 02:44 PM
magictorch's Avatar
Default good advice
Hi, sounds good-ill try and get the DFI board hopefully it wont become too difficult to get in the near future. Seems to be a lot of 939 stuff dissapearing fast. I got the opteron from tiger direct $220-made last month 2007, stepping wsnt CCBE but a guy who got the same 2007 chip found it easily went to 2.4ghz on stock cooling. I'm not wanting anything much from it-just to hold steady. Came with a huge copper 4 pipe heatsink and fan! shame it wont work in my crappy emachines....but its got me interested in building one up now.
cheers.
Good AMD/Ati 580x chipset Motherboard? qwerty CPU's and Motherboards 1 October 26, 2007 01:06 PM
Opteron Experiment xrmarcis CPU's and Motherboards 8 September 24, 2007 12:44 PM
would a 8800GTS be bottleneck by an opteron 165@2.4ghz magictorch CPU's and Motherboards 16 June 19, 2007 07:57 PM
opteron 165 will not POST magictorch Troubleshooting 13 April 9, 2007 02:34 PM
AMD rolls out 3GHz Opteron Babrbarossa Press Releases & Tech News 1 April 9, 2007 06:11 AM
