Old June 23, 2008, 12:21 PM
zlojack's Avatar
Default Is an E8500 enough?
Maybe this is a dumb question, but is it enough for my system? Will I get the most out of my cards?
The reason I ask is because I have a bit of a financial crunch and I need to sell some stuff. The QX9650 has been fun, but I need to sell and replace with something cheaper. The E8500 should get me an easy 4GHz if not more, so I'm thinking about going that route.
Old June 23, 2008, 12:36 PM
Oversized Rooster's Avatar
For most games, raw GHz will matter more than core count, so you'd probably be better off with a faster dual-core rather than a slower quad for that use.
Machine: Intel 6800K | Asus X99-E | 32GB Corsair DDR4-2666 | 500GB Samsung 960 EVO NVMe | 6TB WD Black | 2 x 4TB Hitachi 7K4000 | Corsair 750D | Seasonic XP-860 Platinum | 4GB GTX 970 G1 Windforce | 2 x 27" Samsung S27D390HS PLS | Win10 Pro 64-bit
Old June 23, 2008, 12:40 PM
zlojack's Avatar
I should clarify, I game a lot. Do a little bit of video editing and I fold 24/7.
The new GPU client is promising and maybe I can take a little more advantage of my cards at the sacrifice of CPU power.
Old June 23, 2008, 01:23 PM
Eldonko's Avatar
Hardware Canucks Reviewer
You are going to get alot more WUs with a quad!
Old June 23, 2008, 01:26 PM
zlojack's Avatar
I know...
But I need to sell some stuff or I'm going to be in trouble with the CRA.
Old June 23, 2008, 01:30 PM
Eldonko's Avatar
No point in getting a 8500 over an 8400 or 3110 is there? I guess if you are a bencher this is a point but if you oc the chip 8400 will be fine.
Old June 23, 2008, 01:32 PM
zlojack's Avatar
True. That's probably better.
I'm looking for a good batch that can get me into the 4GHz + range with low voltages. I just figured the 8500 would be more likely to hit 4+, though as we all know, that's not always the case.
Old June 23, 2008, 01:56 PM
Eldonko's Avatar
Pretty much any 8400 will do 4Ghz if you have a half decent HS, its just a matter if its at 1.28v or 1.35v. Average is probably 1.32-1.33v, either way it will be low vcore.
Old June 23, 2008, 02:29 PM
matsta31's Avatar
I must have a problem then, I am at 1.36 and doing 3.9 stable. I mean I can boot with 1.33- 1.32 v core at 4ghz, but I wont be able to run small ftt for a significant (more than 6 hours) amount of time.
Sold hardware again.....
Currently using WHS hardware....
Old June 23, 2008, 02:31 PM
3.0charlie's Avatar
My E8400 needed 1.39V for 4.0 stable. It was bought very early, right after the release.
Hydro-Quebec is salivating...
