Old June 18, 2008, 05:31 PM
Default bios setting
Hi,
in the bios i have an option called "EIST" should i disable this or enable it?
I have an E8400 running at stock speeds.
thx in advanced
Old June 18, 2008, 05:46 PM
SugarJ's Avatar
This lowers your multiplier and voltage when there is low usage of your CPU. Most overclockers disable this, but it is fine to leave enabled for stock operation.
Old June 18, 2008, 06:36 PM
I will disable it i guess , i don`t think it should give me problems?
One more question=) the option plug and play O/S should i set this to NO in bios with windows xp?
Old June 18, 2008, 08:08 PM
sswilson's Avatar
Should be yes to allow the mainboard and OS to talk to each other WRT plug and play hardware resources.
Old June 24, 2008, 06:41 AM
Yea EIST is baiscally a "power saving" option, good blurb on it here:
AnandTech: Intel's Pentium Extreme Edition 965: The Last of a Dying Breed
Q6600@3.15Ghz|CNPS9500|GA-EP45T Extreme|GSkill 2GB 1333MHz|Sapphire 4850|OZC GameXtreme 700|XP64
Old June 24, 2008, 09:45 AM
Originally Posted by maurier View Post
Hi,
thx in advanced
No overclock? Leave it on.
Old June 24, 2008, 09:50 AM
Eldonko's Avatar
Hardware Canucks Reviewer
It just saves you power when your CPU is idle, at stock run it, with oc turn it off.
