-   -   upgrade.. (http://www.hardwarecanucks.com/forum/cpus-motherboards/7955-upgrade.html)
Bdog454 June 14, 2008 04:55 AM
upgrade..
i have a - Asus PTGD1-LA (Grouper) Motherboard is there anyway i can get the hp biso off so i can overclock my cpu? or is there a better cpu i could buy that my motherboard will support
my cpu is a Intel Pentium 4 550J
i was thinking of getting Intel CPU 1 x Intel Core 2 Duo E4600 2.4 GHz ( 800 MHz ) - LGA775 Socket - L2 2 MB - Box
will that work in my motherboard? they are both 775 sockets and it says my real clock is 200MHz but my Effective clock is 800MHz
so it should work? *fingers crossed*
SugarJ June 14, 2008 09:14 AM
Your board is probably too old to support a Core 2 CPU.
If you're looking to OC or even if you're not, the cheap and good option is a new mobo, the Gigabyte GA-EP35-DS3L. Can be had for $93 at NCIX. No Raid, No Firewire, No SLI or Crossfire.
The E4600 is about $140, I'd save up another $60 for an E8400 if I were you.
belgolas June 14, 2008 01:40 PM
The GA-EP35-DS3L is an amazing board. Highly recommend.
