Old May 31, 2008, 08:12 PM
elninio's Avatar
Default Cable sleeving in toronto?
First, I would like to apologize for not knowing where to post this. I've posted here I hope it is not a problem...
Where can I buy some cable sleeving in the Toronto area (Ontario)?
Old May 31, 2008, 11:19 PM
JD JD is online now
I'd be interested to know as well. Seems wasteful having to order it from the US...
Old May 31, 2008, 11:25 PM
Supergrover's Avatar
I used to get mine from Bigfoot, but since they closed IDK.
I am glad I got a wack of it kicking around.
R.I.P.
Old June 1, 2008, 12:17 AM
You can get heat shrink and other cable wrapping at some Canadian tires, depending how big their auto departments are and so forth but most of them do have some form of sleaving because it's used in cars a lot. I bought some at the Danforth/Main St. location a few months ago.
Old June 1, 2008, 08:09 AM
elninio's Avatar
Where exactly? What is the store called? I need cable sleeving like the mutants in the movie total recall needed air!
Old June 1, 2008, 08:26 AM
Xoxide Wire Sleeving Kit (Black)
Xoxide ships to canada.
R.I.P.
Old June 1, 2008, 08:50 AM
vinister's Avatar
Get it from high-end car audio stores. If they don't know where to get it tell them Staub and DEI stock it, among other distributors.
Mobo: DFI 790X-M2R
Proc: AMD PHENOM X3 720
Ram: OCZ Platinum 2X 2GB @ 1066
VIDEO: 3 x Visiontek HD3870
Old June 1, 2008, 07:03 PM
DK2 DK2 is offline
try here;
Welcome to Active Stores
Sayal is next door, likely better selection and price.
Dixie and Matheson in Mississauga.
Old June 1, 2008, 07:15 PM
sswilson's Avatar
Originally Posted by DK2 View Post
try here;
Heh... nice find, next time I need 250 feet of heatshrink I'll give them a dingle... :)
Old June 1, 2008, 07:37 PM
Frozen CPU is my dealer.
James
