Old October 5, 2017, 07:51 AM
Dark Knight's Avatar
Originally Posted by 486 View Post
Microcenter and CC just got stock, 1-2 per store though. Mikes, Newegg, NCIX, DC, BHPV, PCC are all empty, not even in warehouse. Select retailers limited availability, in market-speak.
Not 1-2 per store for Microcenter. It's at least 10 and limited quantities in stores like in NY for example. However Microcenter has said they have very little quantity on hand so those 10 will go very quickly due to high demand. Either way Coffee Lake should be good on X99 6 core pricing it should push it even further down eventually.
Old October 5, 2017, 07:57 AM
486's Avatar
486 486 is offline
Newegg just got stock. Microcenter in Westbury LI, NY and Detroit have 1 of each kind. It is like live update, really.
Fractal Design R5 + Seasonic X-660 650W
Asus X299 TUF Mark 2 + Intel i7-7800X + G.Skill Ripjaws V 3200 8GB x 4
Samsung 950 Pro 512GB + Samsung 850 Pro 512GB + HGST 5400RPM 2TB
Evga GTX 1080 FTW 8GB + BenQ BL3201PH 4K 32"
Old October 5, 2017, 08:13 AM
SugarJ's Avatar
SKYMTL, do you have a 8350K sample? I'd love to see a comparison between that and a 7600K. Both unlocked quad-cores......
Old October 5, 2017, 08:41 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Unfortunately we were only sampled two processors. Looking into buying the others but right now I don't want to fight with the buying public for stock.
Old October 5, 2017, 08:51 AM
Lysrin's Avatar
Did read from stem to stern. Great info and it cleared up several things for me regarding the tech.
It does make me want an 8700K. I'm still running 4790K too with a reasonable OC but I would still like to get more cores. I agree with everything you are saying FreeKnight, but I still might do it anyway!
I guess the biggest question for me right now is I know we have briefly discussed Ice Lake on here but I believe we aren't likely to see that until 2019? If that is true then upgrading to Coffee Lake without another major bump until 2019 doesn't seem too bad; that seems more like the regular cadence again. But if there is something else coming in between Coffee and Ice (Cannon...? or only for mobile perhaps?) then that would make me hesitate upgrading between now and Q1 2018 say, to avoid jumping too quickly.
Excuse me... I have to go consult pcpartpicker
Old October 5, 2017, 09:28 AM
Cannonlake has been expected to be mobile only for some time, and at this point it appears to be rolled into this multi generation 8th Gen family (Kaby Lake refresh mobile, Coffee Lake desktop, Cannon Lake mobile). It's continued delays have seen it go from the "8 core desktop" (VERY early on) to "desktop" to "mobile only".
Ice Lake is being aimed towards Aug-Sept timeframe unless there's a delay. Tiger Lake is 2019. Sapphire Rapids is 2020 (new uarch).
If you don't need anything now, sure, wait? If you need something now, might as well get a Coffee Lake or Ryzen 7 depending on your exact needs. You may even want to consider a 7800X or 1900X if you actually need more PCI-E lanes.
Old October 5, 2017, 10:04 AM
SugarJ's Avatar
Newegg.ca has stock on the 8350K.
Old October 5, 2017, 10:24 AM
Hmmm, i7 8700k looks impressive, if I was to go that way as in team blue how well would overclocking go with 2666mhz ram, do you need higher speed ram?
These ram prices are killing my upgrade idea and the higher speed 3000/3200mhz ram are just way too much for me to justify spending.
Gaming FX 8350 stock / Tuniq Tower 120/ MSI GTX 1070 Armor / G Skill 32GB / S12D 850w/ GA 990FXA-UD3 /SSD 240GB , WD1TB FALS, 3TB Toshiba / Dell IPS 1920x1080/ Win 10 64
Daily Use x4 965BE 3.6GHZ/GA 970 Gaming/ R7 265 1GB /EA750w/4x4GB ram/Win 10 64 and 24TB of hdds
  #19 (permalink)
Old October 5, 2017, 10:26 AM
Queens/Flushing had about 10 in stock and are already sold out. NJ had less and are also sold out. Seems like a few of the other store locations I checked are sold out.
  #20 (permalink)
Old October 5, 2017, 10:49 AM
486's Avatar
486 486 is offline
A week ago I got 2x4GB 3200 DDR4 GSkill from Newegg at 55 CAD. Half-price. There was only a single package though, and I needed two. It seems Newegg sells off left-overs at decent discount. Lucky purchase.
Intel officially announces 8th gen Coffee Lake Lysrin CPU's and Motherboards 14 October 4, 2017 06:53 AM
Will coffee lake be available for purchase on Monday? supaflyx3 CPU's and Motherboards 30 September 14, 2017 02:19 PM
Should I wait for Coffee Lake? fubar New Builds 16 August 29, 2017 12:44 PM
