Old March 13, 2017, 06:44 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Default AMD Ryzen 7 1700X Review; Testing SMT - Comment Thread
AMD's Ryzen 7 1700X is a CPU that offers 90% of the 1800X's performance in a much less expensive package. But how does it fare against Intel's competition without SMT enabled?
Read more here: AMD Ryzen 7 1700X Review; Testing SMT
Old March 13, 2017, 07:53 PM
IRQ Conflict's Avatar
Iím sure that most of you skipped to this section
Why no 1% Low's?
Edit: From what I am hearing Ryzen may not achieve much higher clocks on air but further improvements with newer BIOS' may give you those clocks at a reduced voltage and therefore less heat.
Old March 13, 2017, 08:17 PM
SKYMTL's Avatar
We will be adding frame variance to upcoming reviews but not yet.
Old March 13, 2017, 09:04 PM
belgolas's Avatar
As someone who uses his computer primarily for gaming Ryzan is a disappointment for me. Some are saying the 4 and 6 cores will be better for gaming but they are rumored to be even clocked lower than the 1800x. The Z270 motherboards are also better IMO. We also know that Intel's 6 core processors are coming out and they should match the 7700k clock for clock.
If Ryzan didn't have significantly lower performance in some games I would consider switching as I like to give money to someone other than Intel as we need good strong competition. For gaming a 7700k clocked at 5ghz is still king and I don't see any Ryzan CPU beating it.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Old March 13, 2017, 09:46 PM
EmptyMellon's Avatar
Great review SKY. It was nice to read it all, now that the R7 Hype-train has departed the station.
Old March 14, 2017, 05:36 AM
Bartacus's Avatar
Apparently the heat is being misreported, to the tune of 20C. The 1700 apparently is the only chip properly reporting heat, according to this anyway:
https://www.overclock3d.net/news/cpu...egree_offset/1
Old March 14, 2017, 06:10 AM
More fuel for the flames... 4C/4T testing on Ryzen... saw this linked over on H.
https://www.youtube.com/watch?v=DQilK2dOJTg
heatware
Old March 14, 2017, 07:17 AM
MARSTG's Avatar
[QUOTE]Based upon the testing in this review, the 1700X provides a much better value proposition than the 1800X ever could. [QUOTE]
And 1700 has even more, and while overclocked at 4 GHz is within 1% of 1800x@4.0 GHz. Talk about value. However we can see it really sucks at gaming. For the moment at least. So gamers will still pay Intel while professional users can start paying AMD.
Old March 14, 2017, 09:59 AM
magictorch's Avatar
Good to see a balanced review after the dust has settled from the 1800x
On the one hand its very exciting (lots of compute power) but on the other there seems to be something missing (low res gaming issues and limited overclocking).
I guess you cant expect both-bit intel might plug this gap-as there is demand for BOTH it seems.
After buying a 1800x for work and 21:9 60hz gaming it seems a solid bet-but the low res gaming fps are a concern and Im not optimistic that will change after reading the review. In the next few years we may expect to see cheaper high res high refresh rate monitors that could expose this gaming weakness down the road? For now its good.
Old March 14, 2017, 10:24 AM
Some points regarding this:
1) Coffee Lake - The mainstream 6-core Intel processors being referred to - will either show up at end of 4Q 2017 or 1Q 2018. It is more likely to be in 2018 in tandem with Ice Lake, since we still have to see Cannonlake prior to this. Not as soon as some people may be expecting.
2) 5ghz isn't a realistic overclock for a majority of 7700k chips that exist. 4.6ghz - 4.7ghz is. Still by far the best combination of pure speed and IPC you're going to get at this point and time - no doubt about that.
The AMD Ryzen 7 1800X Performance Review Comment Thread SKYMTL CPU's and Motherboards 97 April 7, 2017 08:52 PM
Suggestion,I'd like to see in the Ryzen review. upcoast604 CPU's and Motherboards 15 March 1, 2017 06:39 AM
The AMD Ryzen CPU Preview; Zen Matures - Comment Thread SKYMTL CPU's and Motherboards 23 December 27, 2016 08:54 PM
2015 CPU Cooler Testing Methodology (Comment Thread) SKYMTL Water Cooling 0 December 30, 2014 10:05 AM
