  #21 (permalink)
Old March 2, 2017, 09:07 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Originally Posted by Dark-Colonel View Post
Excellent review Sky!
Just a quick question, did you do any gaming benchmarks above 1080p? I've gone through a couple of reviews and it seems odd but Ryzen seems to kick it up when at 1440p+ for DX11 and DX12 titles.
Just a correction to that. Ryzen doesn't "kick it up" but rather the field tightens up due to the GPU becoming a bottleneck for top-end performance.
  #22 (permalink)
Old March 2, 2017, 09:42 AM
magictorch's Avatar
So you cant add 4 x 16gb ddr4 (<=2400)-just 2 x 16gb modules (<=2400)?
If so to get 64gb you need 2 x 32gb modules- which are not mainstream?
Hopefully the overclocking will improve with water--but maybe not. Still very solid but would like to run 64gb at some-point.
Impressive for the price but intel could counter aggressively with cheaper 8 cores down the road.
  #23 (permalink)
Old March 2, 2017, 09:45 AM
SKYMTL's Avatar
If you need 2x16GB modules stick to ones that operate at 2400MHz or less
If you need 4x 16GB modules, 1866MHz or less.
  #24 (permalink)
Old March 2, 2017, 10:00 AM
Review seems to cover most of what I need to know paired off with other sites reviews I have mixed feelings where the IPC sort of sits in the i7 3770 camp so a bit disappointed there but the 16 threads are very competitive and a win imho.
I'll sit on the side lines for a while and see what happens with the 6c/12t ryzen and 4c/8t.
Thanks for the review.
Ps, SMT1 seems to be causing grief in a few games like BF1 and Total Warhammer.
Gaming FX 8350 stock / Tuniq Tower 120/ MSI GTX 1070 Armor / G Skill 32GB / S12D 850w/ GA 990FXA-UD3 /SSD 240GB , WD1TB FALS, 3TB Toshiba / Dell IPS 1920x1080/ Win 10 64
Daily Use x4 965BE 3.6GHZ/GA 970 Gaming/ R7 265 1GB /EA750w/4x4GB ram/Win 10 64 and 24TB of hdds
  #25 (permalink)
Old March 2, 2017, 10:03 AM
SKYMTL's Avatar
Is there anything else you think should have been added to our review?
  #26 (permalink)
Old March 2, 2017, 10:14 AM
Core scaling?
  #27 (permalink)
Old March 2, 2017, 10:22 AM
magictorch's Avatar
Thanks ordered the 1800x with the asus x370 hero and 2 x 16gb corsair vengeance 2400. Need an affordable number cruncher that can play games. Should be a nice upgrade from a 4930k system.
I hope its stable!
  #28 (permalink)
Old March 2, 2017, 10:23 AM
SKYMTL's Avatar
Single thread performance is there. ;)
As for SMT, it works perfectly fine on Broadwell-E and Kaby Lake as evidenced by the results. If anything, there may be an issue with Ryzen's scheduler that's mucking things up.
  #29 (permalink)
Old March 2, 2017, 10:55 AM
yycraven's Avatar
Great review SKYMTL
I guess I will have to buy some 2x16GB modules stick, instead of using my 4x 16GB modules of 2400MHz.
  #30 (permalink)
Old March 2, 2017, 11:14 AM
MAC's Avatar
MAC MAC is offline
Associate Review Editor
Originally Posted by Dark Knight View Post
Can Broadwell-E handle all 8 DIMM's with 16GB densities at DDR4-3200? I don't think neither Broadwell-E or even Haswell-E can handle that due to IMC limitations and that's been the case with Intel IMC processors for a while (when using all memory banks).
Broadwell-E can handle 128GB (16GB*8) at DDR4-3200, not sure about Haswell-E since kits that large and that fast weren't really around so I can't find them in the QVL documents.
The AMD Ryzen CPU Preview; Zen Matures - Comment Thread SKYMTL CPU's and Motherboards 23 December 27, 2016 08:54 PM
The AMD R9 390X 8GB Performance Review Comment Thread SKYMTL Video Cards 37 July 9, 2015 03:17 PM
NVIDIA GTX 970 SLI Performance Review (Comment Thread) SKYMTL Video Cards 12 November 18, 2014 05:31 PM
Far Cry 2 Hardware Performance Review Comment Thread FiXT Gaming 21 November 30, 2008 09:09 PM
